LB stuffed?
LB stuffed?
Post by missfixit70 » Sun Apr 04, 2010 10:31 pm
Went out to the bongo earlier, remote central locking wasn't working, opened the drivers door with the key, the other doors still didn't unlock , flicked the battery meter onto the the LB - nowt :(
It was fine yesterday drove to Martock & back, LB was working fine (about an hour journey). The weather was horrendous on the way back lots of flooded bits of road, so water must have got in somewhere & created a short I reckon.
Alternator charges ok, split charge is working ok, although the 70 amp fuse (edit not relay :oops: ) had blown (not surprising since there was about 1.5 v on the LB :roll: ) . Intelligent charger wouldn't play at all, so I used the old school, 30 odd yr old "chuck the current in" charger for a couple of hours, got a bit warm, but it pulled the voltage up enough to get the intelligent charger going instead, so I'll leave it charging & see if it gets anywhere & I've disconnected everything on the LB for now. It's a Numax 110AH, only about 18 months old, so it should be replaced under guarantee if necessary, but I could do without the aggro of trying to track down leccy faults :roll:
Re: LB stuffed?
Post by Northern Bongolow » Sun Apr 04, 2010 11:07 pm
mine in the eriba collapsed recently kirsty,could not get it to charge properly after,
jamie has a gadget called a cetek unit in his caravan,flattens completely then charges apparently stuffed batts.
guess what it did the job great,reads like a new battery now!!
dreamwarrior fitted it for him,its described as a battery reconditioner.
Re: LB stuffed?
Post by missfixit70 » Sun Apr 04, 2010 11:15 pm
If it's the same as this one - http://www.vertar.com/ctek/ctek-multi-xs-3600/ then I think that's basically the same as the intelligent one that's charging it at the mo.
dreamwarrioruk
Re: LB stuffed?
Post by dreamwarrioruk » Sun Apr 04, 2010 11:31 pm
thats the nearly the same, jamies is the top spec one. ive just bought the 3600 from fleabay 42 quid delivered. gonna incorporate it into the bongo to do its thing when on hookup
mike, jo and emma
hembramacho
Re: LB stuffed?
Post by hembramacho » Mon Apr 05, 2010 9:19 am
dreamwarrioruk wrote:thats the nearly the same, jamies is the top spec one. ive just bought the 3600 from fleabay 42 quid delivered. gonna incorporate it into the bongo to do its thing when on hookup
Thay's the one that I've got to do exactly the same job. Works a treat, although is does get quite hot - be carefull where you mount it! It also revived my old 'what I thought was goosed' LB from nothing, so I'd recommend one - £42 is a really good price too! =D>
Andrew
.co.uk
Re: LB stuffed?
Post by .co.uk » Mon Apr 05, 2010 9:37 am
My central locking doesn't work on every occassion either. Turn the key and it works fine, the next time nothing. I thought it may have been due to the snow we had here last week but wasn't sure if it was something else. Is it a common problem? Is it easily sorted? I don't have an LB.
[b]G'day from The People's Republic of the Bongo![/b]
www.thomasgorman.co.uk
dreamwarrioruk
Re: LB stuffed?
Post by dreamwarrioruk » Mon Apr 05, 2010 9:42 am
sorry it was 43 but still a good price
http://cgi.ebay.co.uk/CTEK-Multi-XS3600 ... 5d2889582d
mike, jo and emma
hembramacho
Re: LB stuffed?
Post by hembramacho » Mon Apr 05, 2010 10:36 am
dreamwarrioruk wrote:sorry it was 43 but still a good price
Beats the £44.99 I paid. :lol:
Looking at the picture though the connectors look different. On the one I got they're orange comfort connectors, which make it compatible with the indicator panel I got with it.
Andrew
Re: LB stuffed?
Post by mikeonb4c » Mon Apr 05, 2010 10:47 am
.co.uk wrote:My central locking doesn't work on every occassion either. Turn the key and it works fine, the next time nothing. I thought it may have been due to the snow we had here last week but wasn't sure if it was something else. Is it a common problem? Is it easily sorted? I don't have an LB.
At a guess, I'd have expected performance not to vary, but I've been able to tell in the past if battery is not well becuase the central locking sounds a bit sluggish. I imagine you could test things by connecting the +ve of the LB to the +ve of the SB so that the former is augmented by the latter. Then see if the problem goes away.
Re: LB stuffed?
Post by missfixit70 » Mon Apr 05, 2010 11:42 am
If you mean the remote central locking, could be the fob battery is getting low, iffy connection somewhere or the starter battery getting low amongst other things. As you don't have an LB, (take note Mike :wink: ) check the SB voltage if it doesn't work, it may be a bit low.
Re: LB stuffed?
Post by mikeonb4c » Mon Apr 05, 2010 11:49 am
#-o #-o #-o #-o
Other points apply (i.e. my c/l was sluggish when SB was in poor nick)
dandywarhol
Re: LB stuffed?
Post by dandywarhol » Mon Apr 05, 2010 11:51 am
If the relay got damaged then best to fit a fuse before it to save it next time. :?
Re: LB stuffed?
Post by missfixit70 » Mon Apr 05, 2010 11:55 am
dandywarhol wrote:If the relay got damaged then best to fit a fuse before it to save it next time. :?
If that one's meant for me, there is a fuse before & after the relay - Willinton kit, need I say more :wink:
helen&tony
Re: LB stuffed?
Post by helen&tony » Mon Apr 05, 2010 12:41 pm
Have I got a challenge for one of those chargers :lol: :lol: :lol: :lol: :lol: ...an LB that hasn't been charged for 6 years....I doubt it would power a single LED on a hot day in Jamaica if you lit a fire underneath it :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Re: LB stuffed?
Post by mikeonb4c » Mon Apr 05, 2010 1:34 pm
helen&tony wrote:Hi
I may be able to help you with that.
If you light a fire under the battery and place one of those hot air driven Christmas chimes above it:
..and then use that to drive a small electric motor working as a generator.......you ought to be able to generate sufficient power to light maybe one LED.
I'll fetch me coat :lol:
