Engine air bleed plug - where is it
JonWM
Post by JonWM » Fri Apr 02, 2010 3:07 pm
Finally needed to replace the rad - which I have done and got to the replacing coolant bit and now I can't seem to find the air bleed plug. I think I have found the unconnected bleed hose (zip tied to something under thae passenger seat) along with its already fitted but which I think I need to connect to this bleed plug thing.
Wish I had ID'd parts before starting.
Any help - before it starts lashing it down again - would be massively useful.
Jon
Second bongo
White and Silver T reg AFT with Montague conversion
Re: Engine air bleed plug - where is it
Post by haydn callow » Fri Apr 02, 2010 3:18 pm
The bung in the end of that pipe is the bleed bung.....you just remove it and follow the instructions to bleed the cooling system....don't attempt it unless you are sure you understand what is required.
maxheadroom
Post by maxheadroom » Fri Apr 02, 2010 3:19 pm
Bleed pipe is 15-381A top right of the drawing
hope it helps :D
http://www.lushprojects.com/bongopartsm ... mgno=.html
Keep the Faith
JonWM
Post by JonWM » Fri Apr 02, 2010 3:24 pm
I have a pipe with a bung in one end of it - which looks a bit like the 15-19x in the diagram but the other end of the pipe is unconnected - I think it needs to be connected but can't see an obvious point.
Jon
Second bongo
Post by haydn callow » Fri Apr 02, 2010 3:26 pm
I wonder if you have the wrong head fitted without the connector on the head.....going to be a bugger to bleed that...
mister munkey
Post by mister munkey » Fri Apr 02, 2010 3:27 pm
Its not a Ford Ranger head is it?
Post by haydn callow » Fri Apr 02, 2010 3:28 pm
the open end of the pipe should be connected to a small pipe stub above the alternator......yours hasn't got this stub....ford ranger head.
JonWM
Post by JonWM » Fri Apr 02, 2010 3:36 pm
Nope no stub hose fitted above the alternator. Is it Game Over?
If i knew how to send a piccie then I could show you
The other end clearly used to be connected to something - it has a shape about it suggesting fitting and there is the usual hose spring clip on there.
Jon
Second bongo
mister munkey
Post by mister munkey » Fri Apr 02, 2010 3:38 pm
Possibly adaptable. I remember this coming up before.
Someone will know for sure . . . .
Post by haydn callow » Fri Apr 02, 2010 3:45 pm
It is possible to bleed them without a bleed hose connected...However it is much harder and I would suggest you get to one of the VERY Bongo friendly garages and ask advice......Lifting the front to a extream angle may be one way or using a vacuum bleeder
mister munkey
Post by mister munkey » Fri Apr 02, 2010 3:55 pm
Bingo!!!
There is an answer . . . .
HERE
8)
Post by missfixit70 » Fri Apr 02, 2010 4:18 pm
Yup you need a Cross Docking Stock :wink: (thanks Blobber =D> , I keep trying to remember what that bit's called when it comes up on here)
Good detective work MM :wink:
Post by mikeonb4c » Fri Apr 02, 2010 4:41 pm
missfixit70 wrote:Yup you need a Cross Docking Stock :wink: (thanks Blobber =D> , I keep trying to remember what that bit's called when it comes up on here)
Is this the Y-piece metal piping that can be a bit of a swine to (interference) fit? [-o<
mister munkey
Post by mister munkey » Fri Apr 02, 2010 4:44 pm
Maxheadroom might be able to shed some light on this.
Post by missfixit70 » Fri Apr 02, 2010 4:52 pm
This bit (from MM's link if you click on it )
rob900 wrote:Hi all
My Bongo has a Ranger engine with no bleed point at the top of the engine. Bongo bits provide the correct fitting with an extra section to allow fitting of a bleed hose. However fitting looks interesting - appears to be an interference fit in the cylinder head. Has any one ever had one fitted - and if so any advice?
Many thanks
Rob
