Post
by missfixit70 » Wed Mar 31, 2010 10:35 pm
Just make sure whoever does it is ok with the bleeding procedure, get them to give it a proper flush so you're not mixing incompatible coolants & worthwhile getting a new (genuine mazda) thermostat while you're about it, they're not expensive. Also make sure you know what coolant they've put in so you know what you can top it up with if/when necessary (hopefully it shouldn't be).
