My plan is to use cable to wire from the LB going via an in-line fuse to a switch in the dash before finally ending with a 12v socket behind the dash in the form of a cut off 12v extension cable (female end) This will then connect to a 4 way 12v extension to give me hopefully 4 sockets behind the glove compartment powered directly from the LB which can be switched on and off via the dash switch whenever.
Right, questions:
What amp cable do I need to go from the LB to the dash switch and what amp in-line fuse do I need (do I need one - I would think yes to be safer?)
Can I just take 2 wires from the LB, one from the + and one from the -, or would it be better to earth the - instead?
From the dash switch would it be OK to use the original wiring from the 12v extension cable, as there are 2 wires (red and black) and they seem really thick - is there any way to test what ampage they are? The original extension (before I cut the male end off) has a 3amp fuse in if that helps!
Is there an easier way, or am I biting off more than I can chew???
Andrew
