Corner marker
Debs and David
Corner marker
Post by Debs and David » Tue Mar 30, 2010 4:58 pm
I think you will all know what I mean, the little pole thing with a light on top on the front left corner. David wants to know is this wired up and how can he remove it as he doesn't like it?
Debs and David :?:
Debs & David
You Need Degas to Make De Van Gogh
dreamwarrioruk
Re: Corner marker
Post by dreamwarrioruk » Tue Mar 30, 2010 5:06 pm
if you remove the little cover under the steering wheel, check to see if there is a big box on the inside of it with a load of cabling. on the one i stripped out on saturday that is where the controller was. if so then its just a matter of removing all the cables that route around and through to the corner post.
also if you remove it all then pm northern bongolow as his isnt working.
if there isnt then im not much help, sorry
mike, jo and emma
