Whats this then ?? where do i move it to ?
droodle
Post by droodle » Mon Mar 29, 2010 10:25 pm
hi folks .. got my 1st bongo at the weekend .. want to put a leisure battery in but somethings in the way .. what is it and where can it be moved to ?
thanks
Re: Whats this then ?? where do i move it too ?
Post by missfixit70 » Mon Mar 29, 2010 10:38 pm
Anywhere it's out of the way, it's an aftermarket gizmo, not sure what it's supposed to do, Alternator noise filter? Is yours a petrol?
munroman
Post by munroman » Mon Mar 29, 2010 10:39 pm
It seems to be marked 'Alternator Noise Filter', which is apparently meant to cut down interference on the radio.
It can be moved out of the way, if it is earthed then ensure it gets a good earth in its new position.
jumper
Post by jumper » Mon Mar 29, 2010 10:40 pm
it looks like one of those tins of boiled sweets you buy in service stations =P~
Happiness isn't having what you want its wanting what you have.
droodle
Post by droodle » Mon Mar 29, 2010 10:55 pm
cheers folks .. no its a diesel 2.5 auto - i'll get it moved somewhere else.
thedogsbollox
Post by thedogsbollox » Tue Mar 30, 2010 1:26 pm
If it is a diesel then you may not need it. Disconnect and see if the radio is affected.
Post by Doone » Tue Mar 30, 2010 2:04 pm
But don't earth it via the radiator due to the risk of electrolysis.
dandywarhol
Post by dandywarhol » Tue Mar 30, 2010 10:00 pm
.........unless you want to remove the hairs on yer arms :lol:
