electric mirror fault
Posted: Sat Mar 27, 2010 6:00 pm
by Barley 1981
Hello,
Our drivers side electric mirror has stopped working...it still goes in and out but we are unable to adjust it..the passenger one works fine. Is there a seperate fuse for each side?
thanks for reading.
Re: electric mirror fault
Posted: Tue Mar 30, 2010 9:37 am
by jaylee
Hi Barley,
I'm taking that the angle adjustment of the actual mirror on the driver side don't work, as opposed to the usual mirror folding mechanism??
If so? Then I would start looking at the actual switch...
The same fuse for the radio & cigarette lighter also services the mirrors..
It could be a dodgy connection of the poles on the actual right hand side mirror adjustment selection side inside the switch itself? I would hazard a guess they just need a clean...?
I would also look at the loom between the drivers door & the body..? Check where it bends at the clip on the hinge & where the loom goes into the body under the sleeve on the grommet..
The wires can stress & brake at these points.
Hope this helps.?
Posted: Tue Mar 30, 2010 11:30 am
by haydn callow
The mirror functions work off separate motors..
So a blown fuse would cause the mirror to pack up entirely.
As said above...start at the door loom then the switch and work up towards the mirror...they are a bugger to dismantle but it can be done and a new motor fitted if required.
How do I know ?? co's I did it.
