Rear Diff Breather
Posted: Wed Mar 24, 2010 4:36 pm
by hampshire hog
I have a 1996 2.5d 4x4, can anybody tell where abouts it is located as i cant find it. Also is the rear diff oil sae90 (gl-5).Thanks Frank.
Re: Rear Diff Breather
Posted: Wed Mar 24, 2010 5:35 pm
by sparkymik
Posted: Wed Mar 24, 2010 6:11 pm
by rita
Hi,the breather is 26-060
http://www.lushprojects.com/bongopartsm ... no=.html#4
The oil depends on the diff type.
Posted: Wed Mar 24, 2010 6:29 pm
by missfixit70
GL6 if you got limited slip diff
GL5 if not, both sae 90, approx 2 litres.
Posted: Thu Mar 25, 2010 10:36 am
by hampshire hog
Thanks for the replys,my next question is how do i find out what type of diff i have so i can use the correct oil.Thanks Frank.
Posted: Thu Mar 25, 2010 12:19 pm
by rita
hampshire hog wrote:Thanks for the replys,my next question is how do i find out what type of diff i have so i can use the correct oil.Thanks Frank.
Hi, This will give you the original Spec for your vehicle.
http://www.ruzip.ru/eumz/eumzcat.aspx.
Put your Vin No in the second box down ie sgl3 or sgl5 first then the rest of the Vin in the other box and press the square.
Your vehicle details will appear at the top of the page.
ps you may need to use the translator.
Posted: Fri Mar 26, 2010 2:34 pm
by hampshire hog
Thanks everyone, job now sorted. Cheers Frank.
