Rear Diff Breather
- Bongonaut
Rear Diff Breather
I have a 1996 2.5d 4x4, can anybody tell where abouts it is located as i cant find it. Also is the rear diff oil sae90 (gl-5).Thanks Frank.
Re: Rear Diff Breather
Hi,the breather is 26-060 http://www.lushprojects.com/bongopartsm ... no=.html#4
The oil depends on the diff type.
GL6 if you got limited slip diff
GL5 if not, both sae 90, approx 2 litres.
- Bongonaut
Thanks for the replys,my next question is how do i find out what type of diff i have so i can use the correct oil.Thanks Frank.
Hi, This will give you the original Spec for your vehicle.hampshire hog wrote:Thanks for the replys,my next question is how do i find out what type of diff i have so i can use the correct oil.Thanks Frank.
http://www.ruzip.ru/eumz/eumzcat.aspx.
Put your Vin No in the second box down ie sgl3 or sgl5 first then the rest of the Vin in the other box and press the square.
Your vehicle details will appear at the top of the page.
ps you may need to use the translator.
- Bongonaut
Thanks everyone, job now sorted. Cheers Frank.
