Thanks again!
Check to see if the fan flaps are moving as they should, this FAQ should point you in the right direction
Now that is a thought
May be worth pressure testing the system to see if you got any leaks
Yep, can do this as my dad has the kit.
As the heater circuit is the controlling factor in the cooling system (it's flow basically controls the stat), if you don't get it sorted, you could go badly wrong. If you suspect the matrix, bypass it.
So the heating system needs to operate correctly for the stat to open? Ah, that changes things...damn.
dreamwarrioruk
i hear you used radweld, that can spell problems in a bongo with a 13 yr old rad it can easily get blocked by that gunge
Well, it was a bit of a panic measure. It may well have blocked the heater matrix if not gunked up the rad.
id be happy to come and help you with this, im only in york so not far away if thats any help. ill have a look but i might have a spare bleed pipe in the shed.
That would be really helpful. Very kind of you
suggest a chemical flush and complete change of the coolant from all orrifes, have you put in a new gen stat from mazda as the compatable ones can cause probs. refit and bleed
OK. I will get all the stuff ordered....I take it you are up to speed with all this? To be honest I feel a bit out of my depth at the moment as I'm not familiar enough with the Bongo yet
If I get all the parts your help will be very much appreciated. Will PM you!
You do not need a zenner diode to do the temp gauge mod
Yep, I realised that as soon as I re-read the factsheet.
Would be interested in the volts/current your hospital made coolant alarm is putting into your coolant.
I will let you know. I think the idea was using the conductivity of the coolant to complete a circuit...a drop in coolant would break the circuit and trigger an alarm. Otherwise it's a wait and see situation. My dad has some header tank floats that trigger a switch stashed away too.
I would be more than happy to shell out for a ready made one, but I'm practically penniless for the next few weeks due to having no income after a car crash
Never rains eh?
