From examination, the Mazda stat has features that the other stats don't - the taper and seal.
I have found out what the taper and rubber (which do not appear on any other stat I have tested) are for.
The taper has been machined to create a lip to accommodate the extra seal making it captive on the brass shaft.
Hence, the seal moves up and down with the stat as it lifts/lowers.
The extra seal seems to be a wiper seal to keep the rod section clean - a good feature.
Results of heat tests show that the Mazda stat reacts quicker than the Blueprint. ie: opens (responds) quicker throughout the temperature range.
The following may be a peculiarity of the stat I tested (I have only tested ONE Mazda stat cos Ian will not give me any more
Heat tests
On the FIRST test, the Mazda stat was slow to respond.
On subsequent tests, the response temp/lift improved by 4 degrees - these subsequent tests were consistent.
If this is common to all stats (and not just an odd occurrence on the one I tested), would the following be worthy of consideration?
Before you fit a new stat, put it in a pan and heat it up to maximum temperature. This seems to 'wake it up'.
