Rear Fog Light Wiring
liggy
Post by liggy » Wed Mar 17, 2010 5:47 pm
My rear fog light wiring has come away from the switch when the dash was removed and like a muppet I forgot to note where each wire went. There is 2 cables feeding the switch, 2 seperate red wires and 2 black wires joined. Can anyone tell me which way they have to be put onto the 3 pointed switch I have. Many Thanks
Liggy
Simplezzzzz
thedogsbollox
Re: Rear Fog Light Wiring
Post by thedogsbollox » Wed Mar 17, 2010 5:53 pm
I done mine just a couple od days ago. The two joined black wires are the earth and went on one side of my switch, marked with an earth simbol. One red wire is the 12vfeed and the other is the wire to the fog light. As long as you get the earth in the right place then it will just be a matter of changing the other two till you get the light in the switch coming on when depressed.
liggy
Post by liggy » Wed Mar 17, 2010 6:11 pm
Many Thanks will give that a try hope I dont blow another fuse.
Simplezzzzz
