rumble in first and reverse
michaeln
Post by michaeln » Tue Mar 16, 2010 11:26 am
Can't find an old thread that matches this problem, here goes, 2.5 diesel, auto box. when in first and reverse, there is a low rumbling/grinding noise, disappears in second. Also, getting into gear fron neutral can be a bit uneven- not a smooth engagement. but a grab at higher revs. oil level appears ok, but have not done a thorough check with it fully warm, but was half expecting to find it completely dry. By the way, how does the ATF get topped up? I have booked it into a bongo friendly garage (never let me down so far) but would appreciate some pointers.
Any good transmission specialists in Bristol area?
Re: rumble in first and reverse
Post by francophile1947 » Tue Mar 16, 2010 1:06 pm
ATF is topped up through the dipstick hole.
Do you know when it was last changed, as changing mine made a big difference to the gearbox performance. Also make sure that you check the level properly - engine hot, car in D, handbrake on and, if necessary, wheels chocked.
Alacrity
Post by Alacrity » Tue Mar 16, 2010 3:05 pm
If the gearbox is noisy in 1st & reverse then I am afraid you have geartrain problems within the transmission. Something has failed & is chewing itself & most likely its neighbouring parts up. This will probably be contaminating the oil with metal which in turn causes valves to stick up, possibly the cause of your other issues. Sorry to be the bearer of bad news but thats what it sounds like to me. Most uncommon on a Bongo R4A-EL transmission, not un-common with the Nissan variant of the trans (RE4RO1A & RE4R03A) in 300ZX twin turbo's (RE4R03A).
michaeln
Post by michaeln » Fri Mar 26, 2010 7:49 pm
News at last back from auto specialist- its completely knack'd. now looking for new one.
thanks for replies
You've Been Bongod
Post by You've Been Bongod » Fri Mar 26, 2010 8:48 pm
if its a 2wd i have a good spare box and transfer for grabs can get it shipped to you if needed
Alacrity
Post by Alacrity » Sat Mar 27, 2010 12:40 pm
Sorry to hear that - I would have been happy to have been proved wrong on this one. I would be very surprised if the rebuilder couldn't use 2wd internals in the 4wd tranny so you might want to take up the offer above. I am sure only the extn housing & output shaft will be different.
