Brake Fluid Change. Which D is it? Planning a change soon
B*Witched Blingo
Post by B*Witched Blingo » Thu Mar 11, 2010 11:56 pm
Hello there Techie peeps
Monsuir Blingo is planning to change the Brake Fluid at weekend and has texted to ask you guys if you know of the Brake Fluid grade that we should use. Ady said Dot something, 1, 2, 3, 4, 5 or Cotton?
n.b. edited because I cannot spell :roll:
Last edited by B*Witched Blingo on Fri Mar 12, 2010 12:16 am, edited 1 time in total.
You Tube Films Click Here
Re: Brake Fluid Change. Which D is it? Planning a change soon
Post by missfixit70 » Fri Mar 12, 2010 12:09 am
Dot 4 I'm putting in, tell him to hang fire for a few days & hopefully I'll have mine drained & refilled & I'll be able to let you know how much you'll need :wink:
Post by missfixit70 » Fri Mar 12, 2010 12:10 am
B*Witched Blingo
Post by B*Witched Blingo » Fri Mar 12, 2010 12:11 am
Bugger, I've just been scanning and trying to work out what dot5.1 was and thought urrr dot4. I think ours is ABS.
Okay I will ask him to hang fire. It won't be till weekend anyway. Cheers :D
Post by missfixit70 » Fri Mar 12, 2010 12:16 am
I think I've got 4 litres on standby, which I'm hoping is more than enough, if he's in a position to acquire some :wink:
B*Witched Blingo
Post by B*Witched Blingo » Fri Mar 12, 2010 12:20 am
Not sure where as we only use Millers stuff, not sure if they do Break/Brake fluid. No doubt he will get me to post tomorrow.
Fanks again
Post by missfixit70 » Fri Mar 12, 2010 12:23 am
No worries chuck :wink:
Post by mikeonb4c » Fri Mar 12, 2010 12:30 am
I'll be interested to see if you have any 'before and after' views on how the brakes feel. I bought the stuff to do it 3 years ago just after I bought the Bongo (including a bleed kit, but it turns out you have to butcher the reservoir cap to use it) but couldn't face the hassle. Brakes seem about the same as ever so I've still not bothered. Is it actually possible to do this as on your own or do you need one person pumping the pedal as the other works by the wheel ready to tighten the bleed nipple at end of the pedal stroke? How do you ensure you've bleed all old stuff out etc?
Kirsty's now going to tell me there's a factsheet in the members area that explains it all :oops:
Post by missfixit70 » Fri Mar 12, 2010 12:43 am
No factsheet :wink: (& I don't want to be accused of appointing myself as an expert, so I won't be doing one either) & no butchering for the gunsons eezibleed, just got to drill a 10mm hole in the cap & I've got a bung to go in once it's done (you can get a universal cap that clamps over any hole). I intend to force all the old stuff out & end up with an empty system as I may be removing callipers anyway & I want to know how much is in there.
Refill I think is just a matter of pumping it in using the eezibleed & the pressure from a tyre until it comes through the nipples without any air bubbles, starting at the furthest wheel, then once it's full I'll work around again to make sure. Simplez :wink:
B*Witched Blingo
Post by B*Witched Blingo » Fri Mar 12, 2010 12:47 am
Whatttt???? Holes. Brakes.....Noooo. Oh lord.. :shock:
Post by missfixit70 » Fri Mar 12, 2010 12:56 am
Only in the reservoir cap :wink:
mikeonb4c wrote:I'll be interested to see if you have any 'before and after' views on how the brakes feel.
I'm hoping so, but more to do with the fact I've got a set of EBC Ultimax pads (sounds like a monthly requirement :oops: ) to fit all round, just hoping they're the right ones [-o<
wonkanoby
Post by wonkanoby » Fri Mar 12, 2010 8:53 am
if its any help i went through about 4 small coke bottles full from a 5 litre container
so if i remember right about 2 litres
Post by missfixit70 » Fri Mar 12, 2010 1:27 pm
wonkanoby wrote:if its any help i went through about 4 small coke bottles full from a 5 litre container
so if I remember right about 2 litres
Brill :D , thanks for that, was hoping it would be around that, hopefully won't have to crack open the second bottle :wink:
Is yours ABS or Non?
wonkanoby
Post by wonkanoby » Fri Mar 12, 2010 2:04 pm
non abs
Post by missfixit70 » Fri Mar 12, 2010 2:27 pm
Likewise, cheers :D
