auto gear box
sir geoff
auto gear box
Post by sir geoff » Sun Feb 07, 2010 4:56 pm
gearbox problem no over drive stuck in third gear no hold light flashing oil ok any ideas or please recommend a good garage exeter area
cheers :D
Re: auto gear box
Post by missfixit70 » Sun Feb 07, 2010 5:05 pm
How do you know the oil's ok? Has it been changed, sump dropped & filter cleaned? If not you don't know it's ok - http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=30096 are you checking the level with engine & box warmed up & running? Does the hold light come on when you press the hold button? (just to check the bulb hasn't been tampered with or failed).
Re: auto gear box
Post by Bob » Sun Feb 07, 2010 5:07 pm
Allan's in Plymouth are very good:
http://www.allansvehicleservices.co.uk/
Don't know if he works on gearboxes, but if he doesn't he will know a man who does.
Have you driven it far anough to warm right up? I only ask as the gearbox doesn't 'Lock Up' until it's up to temp.
And a very warm welcome. :D
Re: auto gear box
Post by missfixit70 » Sun Feb 07, 2010 5:14 pm
Seems this one continues from this post - http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=37771 - thought it sounded familiar :wink:
Re: auto gear box
Post by g8dhe » Sun Feb 07, 2010 5:26 pm
sir geoff wrote:anyone know were is the ecu is sited
Down in the Passenger footwell behind the glove box area;
Marked as PCM B2-01 connector
