In Park Switch
Scott
In Park Switch
Post by Scott » Wed Feb 03, 2010 3:24 pm
I'm after the location of the wire that goes to ground when the vehicle is put in park
Location or even the colour code would help
Cheers Scott
The user formerly known as csmcqueen ;)
スコット
Re: In Park Switch
Post by g8dhe » Wed Feb 03, 2010 5:48 pm
The 1995 model has an Inhibitor switch which puts out an Earth to allow you to start;
and is coloured White
jaylee
Re: In Park Switch
Post by jaylee » Wed Feb 03, 2010 5:55 pm
what you got planned Scott, sound like a remote starter?? :wink:
Scott
Re: In Park Switch
Post by Scott » Wed Feb 03, 2010 5:59 pm
jaylee wrote:what you got planned Scott, sound like a remote starter?? :wink:
No just a turbo timer , wire it to the park rather than the handbrake, never use the thing anyway :D
I know, I know [-X :lol:
スコット
Scott
Re: In Park Switch
g8dhe wrote:The 1995 model has an Inhibitor switch which puts out an Earth to allow you to start;
Geoff many thanks
スコット
Re: In Park Switch
Post by g8dhe » Wed Feb 03, 2010 6:17 pm
That's not directly Park as per the Gear Selector.
The Gear Selector switches +12v, and doesn't use the park position in the 1995 models it does however in the 1997 model
and puts it out on a Yellow wire;
also on the 1997 model the Inhibitor switch is different as well it switches the +12v, so better check which year your on!!
jaylee
Re: In Park Switch
Post by jaylee » Wed Feb 03, 2010 6:20 pm
In that case this may be of use to you...? (Second paragraph down. & the boxed quote.) :arrow: just in case you get an unlocking glitch when the TT powers off... Could save some head scratching! You never know! :wink:
Scott
Re: In Park Switch
Post by Scott » Wed Feb 03, 2010 8:13 pm
g8dhe wrote:That's not directly Park as per the Gear Selector.
hmmm mines is a 99 so + switched then, will just stick a small relay in the circuit or just go off the handbrake.
BTW It take it you forum name is you Amateur Radio callsign? Me, i'm only a whipper snapper and carry a G7 callsign but havent used it for while, still have the gear and occasionally can be found on GB7CI but not for a little while :D
jaylee wrote: In that case this may be of use to you...? (Second paragraph down. & the boxed quote.) :arrow: just in case you get an unlocking glitch when the TT powers off... Could save some head scratching! You never know! :wink:
My alarm is completely separate so shouldn't affect it... I hope #-o
スコット
Re: In Park Switch
Post by g8dhe » Wed Feb 03, 2010 9:12 pm
Well if its post Jan 1999 then it could be anything, the Club hasn't got the more recent manual yet. Its either May 1995 to Oct 1997 or Nov 1997 to Jan 1999 that are on-line.
Yup the old callsign is unique so I don't have to worry about it being used elsewhere! Still active but not as much these days but look after the Worthing repeaters for my sins ;-)
jaylee
Re: In Park Switch
Post by jaylee » Thu Feb 04, 2010 12:54 am
Stick around until the timer stops... :wink: you never know.!
I was gonna fit a remote start & TT that came with the alarm bundle.. I thought better of it.. The set up "could" probably be hot-wired... :shock:
