Tyre Pressures
Tyre Pressures
I have just been checking the tyre pressures on the Bongo.
It has 195/80/R15 96S on the front and 215/70/R15/98S on the back.
After reading previous posts on the topic (which to some extent left me more confused than I was before I read them) I have decided that the recommended pressures in the hand book were probably too low and have put them to 36psi front and 38 psi rear. I will then drive the vehicle for a while to see how it feels.
Does this sound reasonable/
tony
tony
Re: Tyre Pressures
It's a good starting point
After a while try an extra couple of PSI in each, to see if that feels better. I've got 225/50x17 tyres at 40PSI all round. The original recommendations are generally thought to be to low, as they're based on the old Japanese tyres.
- mikexgough
Re: Tyre Pressures
Sound advice from John....... I'm (hands up and declares - ready tp be shot down...
) 38F / 40 R...... I prefer it like that....did try 40/40 & 40/42....
- mister munkey
Re: Tyre Pressures
There really is no definitive answer though. No two Bongos are the same. I have a set of low profiles on 18" RX8 alloys that prefer to run at 45/40 but also have 15" alloys when on the same van they sit happiest at 38/36.
It really is a case of Suck It & See to find the right levels for your particular set-up.
Re: Tyre Pressures
Mine are 215/65 all round and I have them at 38 front and 35 rear, if I put any more in the rears they feel very hard and bouncy and I found the middle of the treads were wearing quicker when they were at 38. As already stated it's a case of trial and error to find best setup for your van.
Re: Tyre Pressures
I've got four Dunlop Le Mans RV 215/70R15 98H and have them at 36 front and 38 rear, having tried various other pressures. This seems to suit my Bongo and my driving style. The Bongo is unconverted although I have a removable kitchen which makes my rear passenger side tyre look soft (but only at the bottom
) The limit on my tyres says 40psi anyway.
Alison
- stilldesperate
- Tribal Elder
Re: Tyre Pressures
It takes a lot of miles at the same pressure to realise this, Splitpin, and it's expensive on tyres.splitpin wrote:Mine are 215/65 all round and I have them at 38 front and 35 rear, if I put any more in the rears they feel very hard and bouncy and I found the middle of the treads were wearing quicker when they were at 38. As already stated it's a case of trial and error to find best setup for your van.
This is what over/under pressure does
Cross section
As you say, to high and it's hard and bouncy, (and can loose traction quickly with little warning).
Too soft will tend to "squirm" more on the corners.
Re: Tyre Pressures
Good diagram stilldesperate, shows ata glance the effect of too much or little, your right about squirming on corners if underinflated specially on the fronts.stilldesperate wrote:Cross section
- mister munkey
Re: Tyre Pressures
Another to look out for.
If too low - the edges will wear real quick.
Re: Tyre Pressures
Exactly that happened to our shiny new Toyo's at 36psi on the rear...mister munkey wrote:Another to look out for.
Now running at 40 - u live and learn..
- Tribal Elder
Re: Tyre Pressures
I'm higher than that, about 40/45, tyres if anything a little rounded. But it hugely improved the fuel consumption. and drives better as far as I'm concerned. I guess the weight of the van changes things too, if you it's loaded with a full conversion, and food, water, tents etc., as ours is.
Re: Tyre Pressures
Interesting thread this, there seem to be so many variants on tyre pressures, mine is running on 215's all round and on the pressures as on the door panel (cant remember what tho) lol, it would be interesting if peeps put thier sizes and pressures on for comparison, I am gonna check mine again in the morning and depending on tread wear try a bit more,lol.
- stilldesperate
- Tribal Elder
Re: Tyre Pressures
[quote="David Edwards"]Interesting thread this, there seem to be so many variants on tyre pressures,......[\quote]
I guess it's what you consider "value for money" at the end of the day. If you put loads of pressure in tyres, the rolling resistance is reduced so I guess the mpg will get better, the disadvantage (long-term) is that the tyres will wear (in the centre) faster, also there's the danger that grip on the road is reduced, and there's the possibility of an accident.
- The Great Pretender
Re: Tyre Pressures
Got it about right there SD,.....but........running at the optimal pressure is what we are looking for. In motorsport a probe is inserted into the tyre across the width, sides and centre.stilldesperate wrote:David Edwards wrote:Interesting thread this, there seem to be so many variants on tyre pressures,......[\quote]
Ok so most Bongo owners don't have access to that equipment but after a motorway run of 20ml or so, stop on the hard shoulder of the slip road and feel the tyre across the tread. You can feel if the outsides or centre are at different temperatures. Data logging with pinkies.........simpelsssssss.
To infinity and beyond
Re: Tyre Pressures
Yay, another excuse to play with my laser thermometer
