roof help it won't work ?
suneylouee
Post by suneylouee » Sun Jan 24, 2010 5:39 pm
hi
Can anyone help ? i just had my Bongo cleaned which was great but now the roof will not go up its like theres no electric going to it ? i checked all the fuses that i can find and they are all ok. It worked fine before cleaning and i put the roof up for the valet people so i now there was nothing wrong and put it down " It just now wont work ?????
sandra
mikexgough
Re: roof help it won't work ?
Post by mikexgough » Sun Jan 24, 2010 5:47 pm
is your handbrake on......sounds daft.....but it happened to me........I put it on as it needs to be to work the roof.....then for whatever reason got took off and the roof wouldn't function......till I went to the forum and found I was a numpty......
Check the handbrake is ON
mister munkey
Post by mister munkey » Sun Jan 24, 2010 5:48 pm
1st things first.
Is the Brake light on the dash coming on when you put the handbrake on?
Often its that switch that can cause problems . . . .
Post by missfixit70 » Sun Jan 24, 2010 5:56 pm
There is a switch behind the handbrake if you lift the console that must make good contact, give that a scrape or a rub with some emery cloth.
hembramacho
Post by hembramacho » Sun Jan 24, 2010 6:10 pm
Have you got the engine running whilst trying to get the roof up? If it's been up and down a few times without the engine running it might have just drained the battery and run out of juice.
Andrew
suneylouee
Post by suneylouee » Sun Jan 24, 2010 6:31 pm
all i can say is "you lot are great thanks" something so simple like dputting your hand brake Ha i feel such a fool Thanks every one
sandra
mister munkey
Post by mister munkey » Sun Jan 24, 2010 6:33 pm
You're not the first & certainly won't be the last either!!
Glad all is well.
8)
Post by missfixit70 » Sun Jan 24, 2010 7:24 pm
So who's going to produce some stickers to go next to the roof button with English instructions :?: :wink:
daveblueozzie
Post by daveblueozzie » Sun Jan 24, 2010 7:45 pm
Cabte #-o :lol: :lol: :lol:
Lost without my Bongo.
