pipe rubbing warning...
hi yall,just sorting out the starter motor and there is a rear heater pipe close to the starter and although it has a covering sleeve, this has worn through and has started on the hose,worth checking....
Re: pipe rubbing warning...
Common problem, one of he most common failures after the big hose in front of it & the bleed hose chafing on the alternator. well spotted, save a bit of the old hose to split & sleeve the new one with.
