ECU damage with disconnected battery
Noggin the Nog
Post by Noggin the Nog » Fri Jan 22, 2010 6:30 pm
If I leave the batteries disconnected from the vehicle for quite a while (say 3 weeks) does that damage the ECU at all?
Just want to disconnect them because there is a small current drain somewhere that is flattening them and I can't be arsed to sort that out till it gets a bit warmer
Somewhere out there, up a misty montain is what I have been looking for, one day I shall find it..........untill then I will use a pry bar and 2lb hammer!
Re: ECU damage with disconnected battery
Post by missfixit70 » Fri Jan 22, 2010 6:35 pm
Don't see why it should, ecu isn't hugely complicated on the bongo apparantly.
dandywarhol
Post by dandywarhol » Fri Jan 22, 2010 6:37 pm
Nope - check the interior strip light for draining current - not uncommon :)
The Great Pretender
Post by The Great Pretender » Sat Jan 23, 2010 2:30 am
Noggin the Nog wrote:If I leave the batteries disconnected from the vehicle for quite a while (say 3 weeks) does that damage the ECU at all?
Interesting question, my answer is, i'm not sure. Removing power from electronics (draining the memory) can reset default settings allowing them to work correctly. Just my observations 0 and 1 ain't my best points. :wink:
I'm with Dandy though, check the strip light first. :wink:
To infinity and beyond
Rhinoman
Post by Rhinoman » Sat Jan 23, 2010 12:43 pm
It won't damage the ECU but if its a petrol then it will delete all learned settings. if you need to get it MOT'd after its been laid up then you may need to drive it about for a couple of hours to get it to pass emissions testing.
The ECU, clock and radio will all drain a little current. I've used two cheap solar panels to keep my batteries charged when its laid up.
1995 Ford Freda, 2.5TD, auto, AFT, side conversion.
Post by Doone » Sat Jan 23, 2010 7:04 pm
I have no idea if this will help, but thought I'd mention in anyway. :) Link to 'Sony radio flattens battery'.
