i-alert
BrixhamBongo
i-alert
Post by BrixhamBongo » Wed Jan 20, 2010 2:57 pm
just wondered if anyone has an I-alert fitted ?
Re: i-alert
Post by missfixit70 » Wed Jan 20, 2010 3:00 pm
What is it? Can you post a link or something?
BrixhamBongo
Re: i-alert
Post by BrixhamBongo » Wed Jan 20, 2010 3:18 pm
MountainGoat
Re: i-alert
Post by MountainGoat » Wed Jan 20, 2010 3:29 pm
Looks like Bongo Fury member Haydn Callow has a new website. Does he still give Bongo Fury members a little discount. If this is him then you can always phone or PM him to ask him what it is that you are intrested in.
Tony
Re: i-alert
Post by missfixit70 » Wed Jan 20, 2010 3:34 pm
Same website, just one of his new products :wink: Looks like a good little bit of kit.
apole
Re: i-alert
Post by apole » Wed Jan 20, 2010 4:06 pm
Hi there,
I have one that I bought from Haydn. Works a treat and fits neatly into a switch blank so easy to install neatly.
I'd recommend it from my experience to date.
Andy
BrixhamBongo
Re: i-alert
Post by BrixhamBongo » Wed Jan 20, 2010 4:50 pm
Hi Andy , was it easy to fit and set up ?
apole
Re: i-alert
Post by apole » Wed Jan 20, 2010 4:58 pm
Yes it was quite easy.
Physically fitting it was very easy, pop out a switch blank and pop in the unit.
You have to wire up to switched positive and earth, plus a longer wire that goes out to the engine bay and bolts under the chosen bolt, this is a probe. Then it's a case of tidying up the wiring and all is done.
I think there is info on where to put the sensor probe on the forums.
PM me if you need any more info but it's not hard to install which is good.
Andy
BrixhamBongo
Re: i-alert
Post by BrixhamBongo » Wed Jan 20, 2010 5:00 pm
=D> thanks Nick
mikexgough
Re: i-alert
Post by mikexgough » Wed Jan 20, 2010 5:19 pm
ah.......another slant on a surface sensor job
Re: i-alert
Post by haydn callow » Wed Jan 20, 2010 9:05 pm
Hi, That web shop/site has been up and running 18 months now....I have the (( i-alert )) with red or green display...also the new CUBE's.
Fits in a switch blank....Simple's !!
dandemann8
Re: i-alert
Post by dandemann8 » Wed Jan 20, 2010 9:15 pm
apole wrote:Yes it was quite easy.
Andy
Where exactly in the engine bay is this unit wired upto :?: :? :? :? :?
Bongo no more........... ;-(
Re: i-alert
Post by haydn callow » Wed Jan 20, 2010 9:26 pm
You can fit the sensor under any bolt you like...However we recommend the back of the cylinder head where there is a threaded hole just waiting....correct bolt supplied if asked for. Full photo instructions of the location.
mikexgough
Re: i-alert
Post by mikexgough » Wed Jan 20, 2010 9:37 pm
dandemann8 wrote: Where exactly in the engine bay is this unit wired upto :?: :? :? :? :?
and how accurate in relation to the coolant?....
dandemann8
Re: i-alert
Post by dandemann8 » Wed Jan 20, 2010 9:39 pm
Looks a nifty bit of kit, O and very smart in the world of pimping :lol: :lol: :lol:
