My bongo has been loosing power gradually over several months. I have a flat spot around 2000 - 3000 RPM when it feels breathless, then all of a sudden picks up.
I have been through the filters including the banjo, several times. The problem is only there when the engine is warmed up. It starts lumpy too yet the glow plugs are fine. I have checked and replaced the pipe from in inlet pipe to injector pump.
So, I am suspecting pump/injectors. If you have had yours done, what was the reason and what difference did it make?
Oh... and what was the cost?
Any knowledge would be great. Thanks
