Steering wheel shudder at 60mph
tommywelly
Post by tommywelly » Wed Jan 13, 2010 9:16 pm
When I reach 60mph I feel the steering wheel shudder, as soon as I drop down to 50mph it stops, my mechanic says that it is one of the quirks of a bongo, I am driving 2.5 diesel turbo and apart from filling up with fuel I know nothing about what goes on under the van or the bonnet, any suggestions would be appreciated.
Tommywelly
Re: Steering wheel shudder at 60mph
Post by mikeonb4c » Wed Jan 13, 2010 9:21 pm
tommywelly wrote:Hi
When I reach 60mph I feel the steering wheel shudder, as soon as I drop down to 50mph it stops, my mechanic says that it is one of the quirks of a bongo, I am driving 2.5 deisal turbo and apart from filling up with fuel I know nothing about what goes on under the van or the bonnet, any suggestions would be appreciated.
Tommywelly
Nope, not true! With luck its just the front wheels needing balancing. Might want to check there are no flat spots on the tyres as that has been known to happen occasinally too. My judder went when wheels were balanced. Interestingly, balancing rear wheels also improved smoothness, even at low speeds, as it got rid of excessive rebound on the suspension when on uneven surfaces.
If judder then persists, we'll have to consider other possible causes
Oh and welcome :D
dandywarhol
Post by dandywarhol » Wed Jan 13, 2010 9:24 pm
Worn steering parts
unbalanced tyres/wheels
"flatted" tyres through lying in one place too long
damaged rim
Wheels best balanced by mounting on the balancer by the wheel stud holes rather than the centres
I'd the same problem - it can be sorted, they aren't all that way, mechanic talking shoite
mister munkey
Post by mister munkey » Wed Jan 13, 2010 9:28 pm
Most likely wheels need a balance but also had the same just before a wishbone needed replacing.
Bulwell Bongoleers
Post by Bulwell Bongoleers » Thu Jan 14, 2010 5:13 am
I had the same problem with my Bongo, balancing the wheels improved it. But cured it completely when I had new tyres fitted :D
Manda & Andy
thepickles
Post by thepickles » Thu Jan 14, 2010 10:05 am
Had the same
Had all the wheels balanced Sorted 8) 8) 8)
cheers
Steve :D
Image 'FREEBIE'
littlejobby
Post by littlejobby » Thu Jan 14, 2010 1:37 pm
Had the same , wheels all ok, found the power steering fluid was very low. Topped up and sorted! Apart from the steering rack leak!!
LITTLE JOBBY
" Speaking words of wisdom Let It Be"
wishmaster
Post by wishmaster » Thu Jan 14, 2010 5:52 pm
Hi, same problem here aswell :?
changed the original Jap tyres and the 'jobs a good un' :D
Iz
I have a plan and its as HOT as my pants
IZZY
http://s633.photobucket.com/albums/uu57/izzy2619/
wormey
Post by wormey » Thu Jan 14, 2010 6:11 pm
Me to, I even had the rear seats vibrating and squeeking, wheel balance sorted it.
Daz and debs
dunslair
Post by dunslair » Thu Jan 14, 2010 6:14 pm
wormey wrote:Me to, I even had the rear seats vibrating and squeeking, wheel balance sorted it.
Brilliant 'fat club' car though. Bet the pounds fell of every time you drove it :lol: :lol:
wormey
Post by wormey » Thu Jan 14, 2010 6:49 pm
Sure did, that was after a garage fitted new tyres and wheels all around :shock: , still haven't found my teeth. :lol:
Daz and debs
Ron Miel
Post by Ron Miel » Thu Jan 14, 2010 7:01 pm
Bulwell Bongoleers wrote:Hi
Ditto, ditto.
madmile
Post by madmile » Thu Jan 14, 2010 7:56 pm
Sometimes, ill fitting alloys can be a problem particularly if they need spigot rings (or havent had them fitted). The centre of the hub should fit sug on the centre of the wheel with no movement even before you do up any wheel nuts. This just came to mind as I sold a set of alloys to a chap who had multifit steel wheels and they were a terrible fit...he was having lots of wheel wobble (not wonder :roll: ) and having them balanced didnt help.
tommywelly
Post by tommywelly » Thu Jan 14, 2010 11:33 pm
mikeonb4c wrote:
tommywelly wrote:Hi
Tommywelly
Oh and welcome :D[/Thanks for all replies, I will start by getting wheels balanced, I did have the rear tyres change a couple of weeks ago but I have only been local and not reached 60mph]
Post by mikeonb4c » Fri Jan 15, 2010 12:35 am
Good luck. Lots of good suggestions from various peeps on here. Should keep you busy working out which one of them it is :lol: 8)
