Headlight problems
rev pete
Headlight problems
Post by rev pete » Wed Jan 06, 2010 11:10 pm
Hi folks>> I have lost both Dip beams can anyone tell me regarding fuses and relays I wonder if they are fused togather if a bulb has gone it could have fused the other. I have blue bulbs and they are horrible what bulbs would you suggest to give me a good white light
THANKS [-o<
Re: Headlight problems
Post by g8dhe » Wed Jan 06, 2010 11:42 pm
Wiring diagrams which identify the fuses and relays for 1995-1997 and 1997-1999 are available on-line here;
1997-1999
1995-1997
The pages following those above give the locations of the relays and fuses etc.
OK a picture as well :D But as you don't say what vehicle you have I'll have to guess :!:
However the relay controls both High and Low beams from the Main switch, but the Flash switch is separate so if the Flash switch works but not the Main switch suspect the relay for 1997-1999 models, if neither works suspect the Fuse, no relay involved on the 1995-1997 versions.
Fuse positions well there in the manual as well;
1997-1999
1995-1997
rev pete
Post by rev pete » Thu Jan 07, 2010 3:05 pm
These diagrams are ok but it need somebody to write the headlight fuse/relay positions in words rather than pictures please. this is worse for me than flat pack pictorial instuctions?? I can read wiring diagrams of the older style but without color codes etc etc I am lost. :?
Post by missfixit70 » Thu Jan 07, 2010 3:09 pm
They are fused together, fuse diagrams/numbers/locations are in the members area. the relays are inside the passenger side wing under the bonnet, got little black rubber covers over them, there's a piccy somewhere on the forum if you do a search showing you which relay is which.
Post by g8dhe » Thu Jan 07, 2010 3:49 pm
OK extra pictures added to the first reply but to put it in words means knowing which vehicle year / model you have as they differ!
rev pete
Post by rev pete » Thu Jan 07, 2010 10:41 pm
I had not realised that they would not all be the same so This is a 2.5 diesel high top 4x4 Sreg 1998. Main beam works fine. but headlights go out on Dip beam. I have not been able to check bulbs as we are in heavy snow and it has a battery right next to the expansion tank I did not want to take the battery off and find I was in the wrong ball park. i am now thinking is it likely that two bulbs could have blown togather unlikely but not impossible I suppose. Thanks for your help :oops:
Post by g8dhe » Thu Jan 07, 2010 11:25 pm
OK well in that case its covered by the 1997-1999 manual.
There is only one Fuse involved and that protects both High beam and Low Beam, there is only one Relay involved and again that handles both High and Low beam from the Main switch, so if High beam is working then one of three possibilities;
1. Both bulbs have blown at the same time - not unheard of.
2. The Main switch has broken, and I don't think its easy to get at as its got to be removed from the steering column. I would guess a lower chance than 1. above !
3. The wiring has broken from the switch or to earth points for the lamps, again as both lamps are involved its unlikely but not impossible. I would guess lower chance than 2. above !
I would start with checking the lamps, perhaps the Offside one first as its easier to get at than the Nearside one, they can be a fiddle to unclip see this thread it also covers choices for headlamps that are brighter as well.
If both High and Low beam aren't working then check the 30 Amp fuse in the little box connected to the rear of the Main battery terminal, third from right hand edge. If thats OK then check the relay as shown in the Photo above, Nearside wing, rear most relay of a possible 4 relays (note not all relays need be fitted but there are 4 positions).
rev pete
Post by rev pete » Fri Jan 08, 2010 1:23 am
Thankyou very very much for your help :D
