dash and rear lights not working
dublin26
Post by dublin26 » Wed Jan 06, 2010 9:19 am
Hi, l wonder if anyone can help!! the light on the dash board has gone out and also the rear lights are not working. The front lights are working but only on full. The radio is working. Could this be a fuse problem?
westonwarrior
Re: dash and rear lights not working
Post by westonwarrior » Wed Jan 06, 2010 9:23 am
fuse 8 in the engine bay is main suspect its 15 amp
brorabongo
Post by brorabongo » Wed Jan 06, 2010 12:00 pm
Plus I think they are both off the same relay, which has been known to go.
EDIT: Check here.... http://www.igmaynard.co.uk/bongo/forum/ ... =h270+rear
ボンゴの激怒 pictures
Post by g8dhe » Wed Jan 06, 2010 1:00 pm
If its the Dashboard lights are out check the 15 Amp fuse second row down second in from left by the drivers knee, that covers the Dashboard in 1995-1999 models.
The Tail lights are covered by the fuse 8 in the engine Bay mentioned earlier.
Indicators are covered by a 10Amp third in from left, second row by the drivers knee.
Check out the Wiring diagrams on-line
Bhongo Bhoy
Post by Bhongo Bhoy » Wed Jan 06, 2010 1:12 pm
jaylee wrote:
Fuse 8 in the engine bay 15A will service the dash lights & yer tail...
In fact that explains why yer fuse went... (A short may have blown the fuse) & the chance is your tail lights don't work either...!
spot on Jaylee never even checked my tail lights last night all sorted now .
thanks to all
Jim
that was the advice i got when it happened to me :wink:
dublin26
Post by dublin26 » Thu Jan 07, 2010 5:34 pm
westonwarrior wrote:fuse 8 in the engine bay is main suspect its 15 amp
Thank you for advise, have replaced the fuse ...all is well. Thanks
dublin26
Post by dublin26 » Thu Jan 07, 2010 5:36 pm
brorabongo wrote:Plus I think they are both off the same relay, which has been known to go.
