32 degrees roasting 31.5 warm
buddyh42
Post by buddyh42 » Fri Dec 11, 2009 8:06 pm
can anyone tell me what could be wrong, my heater at 32 is hot but from 18 to 31.5 it is cold to warm but never hot. any ideas folks
That'll Be The Day.........
'99 Silver V6 Moonfleet Conversion
MountainGoat
Re: 32 degrees roasting 31.5 warm
Post by MountainGoat » Fri Dec 11, 2009 8:48 pm
Not really clued up on this Buddy. I have always assumed that heat comes from the engine via the cooling pipes and is regulated by some sort of gate via the controlls. This would lead me to believe that the gate on your heater must be sticking at low temperatures and springing open full when it reaches 32°. But then I could be talking a lot of bosh. :oops:
Tony
BONGOCONGO
Post by BONGOCONGO » Fri Dec 11, 2009 9:43 pm
Had a similar problem with our 2l petrol Bongo which has climate control. Would only blow out cold air until it reached about 32 degrees on the dial. From a previous blog on Bongo Fury, discovered there was a lever just behind the air intake ( under the bonnet) which controls the air input to the climate control. Forward for Summer (cold air from outside) and in the Back position for Winter when it takes warmer air , probably from over the exhaust. Did the trick - now get warm/hot air at sensible values. Will try to find the blog for you.
BONGOCONGO
Post by BONGOCONGO » Fri Dec 11, 2009 9:59 pm
Got it! Go to Techie Stuff, page 4, "What does this lever do?" from Jules59. This might help.
Post by missfixit70 » Fri Dec 11, 2009 10:03 pm
buddyh42
Post by buddyh42 » Sat Dec 12, 2009 2:10 am
thanks for the help will try that when i can see at least 6 inches in front of me
Post by mikeonb4c » Sat Dec 12, 2009 10:44 am
buddyh42 wrote:thanks for the help will try that when i can see at least 6 inches in front of me
Yes, my wife always said she needed at least 6" in front of her before it was worth trying.....
:lol: :lol: :lol:
PS - thats one of the best feed lines I've had in a longtime. Keep 'em coming (or should that be 'it') 8)
munroman
Post by munroman » Sat Dec 12, 2009 11:40 am
Well Allen, I can see over a foot in front of me right now, is it very cold over your way ? :mrgreen:
buddyh42
Post by buddyh42 » Sat Dec 12, 2009 2:27 pm
no typical munroman I can see at least to end of the street but just typical not very well today so unless i get better before dark time then it will have to wait
Post by missfixit70 » Sat Dec 12, 2009 2:35 pm
I think that one missed it's target :wink:
munroman
Post by munroman » Sat Dec 12, 2009 3:36 pm
Kirsty, whatever can you mean, I was of course indicating the weather conditions might be more adverse in Allen's area than in mine! :oops:
teddy
Post by teddy » Sat Dec 12, 2009 7:33 pm
buddyh42 wrote:can anyone tell me what could be wrong, my heater at 32 is hot but from 18 to 31.5 it is cold to warm but never hot. any ideas folks
I have a '99 V6 too and I just mentioned this problem last night to my hubby.
After reading this he went out and found the lever was in the forward position so he moved it back. I must admit it didn't seem to make much difference but it is going into the garage next week for a check so I will ask for it to be looked at.
buddyh42
Post by buddyh42 » Sun Dec 13, 2009 10:47 pm
well was out and had a look and it was in the forward position, so pushed it back into winter, and sad to say it has not made 1 jot of a difference so still no further on, Anyone got any more ideas?
Post by g8dhe » Sun Dec 13, 2009 10:52 pm
Is it actually blowing when its at the lower settings - just not hot ? Or is it not blowing at all until you reach the highest setting ?
Oh and is the Manual system or electronic display version ?
buddyh42
Post by buddyh42 » Mon Dec 14, 2009 2:28 pm
its the electronic 1 and blowing at all temps just not hot till 32degrees
