How do you know if your Bongo has a coolant alarm fitted?
J&P's Bertie Bongo
Post by J&P's Bertie Bongo » Thu Dec 10, 2009 8:25 pm
How would I go about locating a coolant alarm if there is one fitted on our Bongo?
Might sound like a silly question but we have no engine know-how whatsoever.
scanner
Re: How do you know if your Bongo has a coolant alarm fitted?
Post by scanner » Thu Dec 10, 2009 8:28 pm
If it's a low coolant alarm you will have a small LED display on the dash somewhere.
If it's a Mason alarm you'll probably have to have a look under the fascia or check the back of the instrument cluster to see if it's wired in.
dandemann8
Post by dandemann8 » Thu Dec 10, 2009 8:32 pm
A coolant alarm will have a sensor (screw) in the header tank if there is one fitted. :)
Bongo no more........... ;-(
J&P's Bertie Bongo
Post by J&P's Bertie Bongo » Thu Dec 10, 2009 8:36 pm
:? Thanks. Will try to locate these at the weekend when I feel more human.
steviebongo
Post by steviebongo » Thu Dec 10, 2009 8:39 pm
and a mason chirrps on keying on.
Post by missfixit70 » Thu Dec 10, 2009 9:29 pm
& the coolant alarm should beep on start up :wink:
Post by rita » Thu Dec 10, 2009 10:32 pm
You should hear Chirpy Chirpy Cheep Cheep when you start the engine.
I loved that song.
