Just received one of the new micro TM-2 type temp gauges from Haydn. Impressive, fits very neatly in a switch blank. Did a quick and dirty wire up as a test over lunch.
Does anyone know where best to put the sensor on the V6 petrol?
One place that looks good on the V6 is at the front of the engine block. There is an alloy metall casing that connects the large radiator hoses to the block, feeds the stat and has 2 temp sensors in it. I could put the sensor behind the 10mm bolt that holds this casing to the block. Will need to wait until next week when it's in the garage as access is not possible unless ET happens to drop by with his long thin fingers !!!
Would this be a good place, on front of engine block where all the coolant flows?
I've put in under one of the rocker cover casing bolts as a temorary measure to see how it all works, not expecting accurate results like this but it's a gadget and can't just stay in it's packet.
Just to say a big thanks to Haydn, extremely fast delivery, under 24 hours which is impressive and good on him for keeping an eye and investing in new products.
If anyone is interested in what it's like, it looks like this:
Temp gauge, voltmeter, and can control a relay for a fan. All settable for alarm thresholds on temp and battery hi/low voltage.
Initial impressions are it looks well made, cabling is nice and long, sensor has 3 m wiring, has good protection around the cables and joints, display nice and bright, setting buttons work well and it fits so well in existing switch blank although you don't have to use this as case black all round and well finished so could be freestanding.
Andy
