Worrying oil leak :-(
duncsuk
Post by duncsuk » Tue Dec 01, 2009 3:57 pm
As my coolant alarm bleeped longer than usual this morning and I've recently noticed a 'whine' from what I assumed was one of the drive belts, I decided to try and have a look at the water pump, in case the bearing was going and this was causing coolant loss. However, before I could check that out, I came across a worrying oil leak :( towards the top of the engine under the drivers side. Engine quite wet .. though nothing on the tarmac (... as yet) ?
Hope to get time later this week to get her to the garage, but any ideas to prempt the 'ooh, that'll be expensive sir' routine ... ?
Bongo itself (a 2.5 TD) starts/runs okay .. with no engine temperature problem ... if anything, the temp gauge reading a little below centre.
TIA
Re: Worrying oil leak :-(
Post by francophile1947 » Tue Dec 01, 2009 4:33 pm
If you find a diesel-engined one without all that rubbish, there's probably something wrong :lol: :lol: It's muck from the EGR and probably 99% of them have it - it looks worse than it actually is, so, unless your oil level is dropping, smile and live with it (the rest of us do) :lol: :lol:
helen&tony
Post by helen&tony » Tue Dec 01, 2009 4:57 pm
Yes...John's right, and I've blanked the EGR with one of Allans excellent kits, however , there is usually so much tarry residue in the pipes that you will get gunk creeping out as the engine warms the old muck....It's like the lungs of an ex-smoker, really, as it takes an ex-smoker 7 years or so coughing up nicotine tar before they are clear....I speak as one who knows on both counts :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: ...as John says...don't worry about the oil.....
Post by mikeonb4c » Tue Dec 01, 2009 5:10 pm
I get confused by all this. I thought the EGR stuff was on the pasenger side with the exhaust stuff (not that I've ever had a proper go at identifying it so what do I know :oops: ).
What I do know about my Bongo is that under the drivers side is the fuel pump and injector. And what I thought might be engine oil making the side of the engine block look damp was I think diesel from a slightly oily diesel pump. Could this be it? :? Or maybe its been EGR gunk all along (though it looks too 'thin' for that) :roll:
dandywarhol
Post by dandywarhol » Tue Dec 01, 2009 5:22 pm
The exhaust gas comes from the passengers side, around the back and is bled into the inlet manifold under the driver's seat via the vacuum operated EGR valve
Post by mikeonb4c » Tue Dec 01, 2009 6:08 pm
dandywarhol wrote:The exhaust gas comes from the passengers side, around the back and is bled into the inlet manifold under the driver's seat via the vacuum operated EGR valve
Aha! Thanks Dandy and that cheers me up a bit as maybe my Bongo's oiliness is due to that :D
duncsuk
Post by duncsuk » Tue Dec 01, 2009 7:29 pm
Thanks .. that all makes me feel much better. Just ordered a blanking kit to isolate the EGR ... and then I'll clean up that area and keep an eye on things.
BTW ... can anyone point out the specific vacuum operated EGR valve (solenoid) as the one for my A/C is intermittent and I'd like to swap them (as they're about £75 new!!!).
dandywarhol
Post by dandywarhol » Tue Dec 01, 2009 7:51 pm
The AC doesn't work from that kind of solenoid as far as I know - the 2 solenoids are for EGR and engine fast idle. I think the rear one is for the EGR from memory
Post by missfixit70 » Tue Dec 01, 2009 11:38 pm
4 solenoids in all, the rear 2 are for the egr front 2 are for cold start fast idle & a/c fast idle.
