lee-jon
Post
by lee-jon » Sat Nov 28, 2009 1:44 pm
HELP, my bongos heating is only just warm after 20 miles, any ideas??
1998 r reg,2 lt 2wd
Post
by francophile1947 » Sat Nov 28, 2009 1:47 pm
Sounds like a lack of a thermostat
Maybe had overheating problems so stat removed by previous owner
- do you know the history of the vehicle?
Read this thread as local help may be available
http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=29471
lee-jon
Post
by lee-jon » Sat Nov 28, 2009 1:51 pm
only bought it 2 weeks ago from nma in portsmouth, low miles v clean. not sure of history
Post
by francophile1947 » Sat Nov 28, 2009 1:54 pm
lee-jon wrote:only bought it 2 weeks ago from nma in portsmouth, low miles v clean. not sure of history
Take it back to them to sort out, as it's clearly not right. The Bongo heaters generally heat up very quickly.
lee-jon
Post
by lee-jon » Sat Nov 28, 2009 1:57 pm
200 Miles each way, not worth the trip!
lee-jon
Post
by lee-jon » Sat Nov 28, 2009 2:04 pm
Also temp gauge never rises, got stuck on a giant carpark ( m25 ) on way home but temp gauge only just moved a bit,
even though i was stuck for 3 hrs!!
dandywarhol
Post
by dandywarhol » Sat Nov 28, 2009 2:10 pm
Without worrying you too much, the 200 mile trip might be a neccessity - sounds like the thermostat has been removed, as franco says, to guise a potentially serious overheating problem
dandywarhol on Sat Nov 28, 2009 2:39 pm, edited 2 times in total.
stilldesperate
- Tribal Elder
Post
by stilldesperate » Sat Nov 28, 2009 2:20 pm
Is it loosing coolant?
"The older I get, the faster I was"
joe-robo
Post
by joe-robo » Sat Nov 28, 2009 5:44 pm
hi
i have just got a 2lt petrol '98 Rreg. aswell and mine is the same, if you leave it ticking over the neeedle rises to the 11 oclock position (or if you're in heavy traffic) and when your moving it drops back down to the 'C' as mine does this.
my heaters never get hot hot, just warm, i have no coolant loss....
i have no idea if this is normal on the 2l petrols or not????.....i've finaley got a day of work this monday so i'm taking mine back to wheelquick to see....
Post
by mikeonb4c » Sat Nov 28, 2009 7:04 pm
When I had these symptoms on my Nissan Sunny it turned out to be a thermostat that wasn't closing off the flow. Although Bongo thermostats fail (I'm told) in the closed position, there's a possibility that these are thermostats that have failed/stuck in the open position. The only way to find out is to open the housing and see if there is a thermostat in there and - if so - fit a new one and see if the problem disappears. If there isn't one in there then that's not so good and a 200 mile trip (or less for joe-robo to Wheelquick!) seems unavoidable (but only once it has been established it won't be a wasted journey - maybe they would agree to the cost of a local specialist fitting a new thermostat, though you'd get to make it clear that if they discover there isn't one then the dealer must be responsible for the consequences of fitting one to what might be a compromised cooling system that might need a new rad., water pump etc.).
Good luck and keep us posted - these sound like interesting cases
stilldesperate
- Tribal Elder
Post
by stilldesperate » Sat Nov 28, 2009 7:39 pm
mikeonb4c wrote: - maybe they would agree to the cost of a local specialist fitting a new thermostat, though you'd get to make it clear that if they discover there isn't one then the dealer must be responsible for the consequences of fitting one to what might be a compromised cooling system that might need a new rad., water pump etc.).
Good advice, Mike.
The route of getting an "expert" report and litigation is something that I feel few are prepared to see through.
Your suggestion helps both parties, with minimal outlay / inconvenience.
SD
mikexgough
Post
by mikexgough » Sat Nov 28, 2009 7:42 pm
Take it back........worth the 200 mile trip.... as others say ....no thermostat in the system which is/could be hiding another problem.... get them to fit one....or your money back....
stilldesperate
- Tribal Elder
Post
by stilldesperate » Sat Nov 28, 2009 8:24 pm
mikexgough wrote:Take it back........worth the 200 mile trip.... as others say ....no thermostat in the system which is/could be hiding another problem.... get them to fit one....or your money back....
Do you not think that, if there's no stat, they'll apologise profusely, put one in, and send you on your way?
mikexgough
Post
by mikexgough » Sat Nov 28, 2009 8:27 pm
stilldesperate wrote:mikexgough wrote:Take it back........worth the 200 mile trip.... as others say ....no thermostat in the system which is/could be hiding another problem.... get them to fit one....or your money back....
Yes but then if there is a problem, that was shown up by having a stat fitted, they would be liable to rectify...
stilldesperate
- Tribal Elder
Post
by stilldesperate » Sat Nov 28, 2009 8:44 pm
mikexgough wrote:stilldesperate wrote:mikexgough wrote:Take it back........worth the 200 mile trip.... as others say ....no thermostat in the system which is/could be hiding another problem.... get them to fit one....or your money back....
Let's hope they do that.
SD
