Coolant Loss
thepickles
Coolant Loss
Post by thepickles » Thu Nov 26, 2009 1:27 pm
I know this has been discussed a lot :shock: :shock:
But Mrs P went for a spin today, coolant alarm went off :cry: :cry: :cry:
Temp remained normal 8) 8)
But all coolant in header tank gone
whats the next step
Steve :D
Image 'FREEBIE'
dave_aber
Re: Coolant Loss
Post by dave_aber » Thu Nov 26, 2009 1:33 pm
Stop driving.
Image...Image
Re: Coolant Loss
Post by francophile1947 » Thu Nov 26, 2009 1:38 pm
You need to check all the hoses for leaks and don't drive it until you have bled the system - if the header tank is empty, you will almost certainly have got air in the system.
If you can't find any leaks, you'll need to check if the system is over-pressurising due to a head gasket gone :( Is there steam coming from the exhaust?
Re: Coolant Loss
Post by mikeonb4c » Thu Nov 26, 2009 1:45 pm
If you stopped as soon as the coolant alarm went off, then you'd think it must be a substantial leak for header tank to have emptied, as the LCA should go off while there is still fair bit left in it. Did you spot any coolant anywhere underneath the vehicle? Do you have a Mason or TM2 alram fitted? How far are you from home, in terms of recovering the vehicle (I'm thinking that a v. short trip with header tank topped up might just be possible, though I suspect I'll get shouted at for suggesting that)
PS - thank heavens for the LCA though eh? Well done Haydn =D>
thepickles
Re: Coolant Loss
Post by thepickles » Thu Nov 26, 2009 1:59 pm
As Mrs P was driving close to home the low coolant alarm went off
the temp reading was at 88
slight steam from under bonnet
header tank bone dry
as for which coolant alarm the one with the temp gauge and low coolant alarm
'ANY EXPERTS IN MY AREA WANNA TAKE A LOOK' I don't know of any bongo friendly garages near me :cry:
cheers
Steve :D
Image 'FREEBIE'
Re: Coolant Loss
Post by haydn callow » Thu Nov 26, 2009 2:57 pm
The alarm would have gone off when the coolant in the tank was just below the FULL line.(above the LOW).....If SWMBO stopped at once, the tank should still be reasonably full ..unless it was a massive leak which should have been obvious.
As already said......providing the temp stayed much the same as normal and your Bongo gauge didn't swing over, you have probably got away with it...Don't drive it untill the faults is repaired and whatever you do....GET IT BLED ACCORDING TO THE INSTRUCTIONS........
thepickles
Re: Coolant Loss
Post by thepickles » Thu Nov 26, 2009 3:16 pm
haydn callow wrote:The alarm would have gone off when the coolant in the tank was just below the FULL line.(above the LOW).....If SWMBO stopped at once, the tank should still be reasonably full ..unless it was a massive leak which should have been obvious.
Yes have your TM-2 combined fitted
Hope fully a burst hose, SWMBO could not give me accurate info, but did say temp at 88 and needle did not swing
slight steaming from bonnet when she got home
I can't look in the daylight until Saturday so I will have to wait
what coolant do you guys and gals recommend ??
Don't need this right now but that's Bongo ownership for you :roll: :roll: :roll:
cheers
Steve :D
Image 'FREEBIE'
thepickles
Re: Coolant Loss
Post by thepickles » Thu Nov 26, 2009 8:59 pm
Just had a quick squint under the bonnet
water every where , took the rad cap off, rad full ,rubber seal to cap a bit out of line put this right
water around top of rad could the cap have been the prob ??
but what caused this???
cheers
Steve :D
Image 'FREEBIE'
thepickles
Re: Coolant Loss
Post by thepickles » Fri Nov 27, 2009 2:44 pm
I got to flush and bleed the system
What Anti Freeze to you use ??????????? and do use tap water or distilled water :?: :?: :?: :?: :?:
I always use this in my bike with distilled water
http://www.halfords.com/webapp/wcs/stor ... yId_229902
cheers
steve :D
Image 'FREEBIE'
Re: Coolant Loss
Post by mikeonb4c » Fri Nov 27, 2009 2:54 pm
thepickles wrote:Hi,
cheers
steve :D
I just used tap water when I refilled mine (though I am in a non-hard water area, not sure what best practice is either).
While establishing where the leak is, could you not just use tap water (don't even bother with wasting antifreeze, esp. as it should still have a decent amount in it). Bleed it properly of course (and or give up because while running engine to do the bleed, it becomes obvious where the leak is coming from). If the leak is slow/mysterious, then include some u/v dye if you have it (and a u/v torch to later spot the spillage areas) and keep the Bongo on local driving until problem resolved.
Others care to comment? :roll:
thepickles
Re: Coolant Loss
Post by thepickles » Fri Nov 27, 2009 3:17 pm
cheers
steve :D
Yes I am planning to top the system up with tap water and then gently run the bongo whilst leak checking
if I solve the problem I will fix it and then flush and fill with fresh antifreeze
At first look I feel the top of the rad may have burst
Image 'FREEBIE'
Re: Coolant Loss
Post by mikeonb4c » Fri Nov 27, 2009 3:26 pm
thepickles wrote:At first look I feel the top of the rad may have burst
I seem to recall there have been a few incidents of that - something to do with it being plastic and splitting ( I await my turn for it to happen :( ). Have a search if you get a moment.
Good luck 8)
thepickles
Re: Coolant Loss
Post by thepickles » Sat Nov 28, 2009 11:53 am
I have found the source of the leak 8) 8) 8) 8)
Engine and everything else all OK 8) 8)
Bottom right side of the radiator is leaking near the bottom pipe
can this be fixed :?: :?: :?: :?: :?:
VID
Steve :D
Image 'FREEBIE'
Re: Coolant Loss
Post by mikeonb4c » Sat Nov 28, 2009 12:37 pm
Vid too dark for my PC - Is it all metal around there? Does anyone still braze radiators? I wonder if isn't best just to get a replacement though as brazing would cost, car would be out of action, long lasting result might be uncertain. :roll:
mobilecat
Re: Coolant Loss
Post by mobilecat » Sat Nov 28, 2009 2:19 pm
Pull the rubber quite hard on the seal on the filler tank cap - Inn the end, mine was that - and we tried everything else first. It could of course be that in conjunction with something else. Tiny holes in that rubber seal do a whole lot of leaking under pressure. We didn't find it in time - new radiator too :(
