Flashing Dummy Alarm LED.
dandemann8
Post by dandemann8 » Wed Nov 25, 2009 10:32 pm
Good evening out there in Bongoland, having not fitted an alarm/immobiliser to my Bongo I was thinking of fitting a dummy flashing LED for a visual deterrent for starters but I have a couple of questions regarding how would this work as I don't know anything about wiring electrics :? [-o< , and how would it effect my battery :?:
Any advice would be most welcome.
Duncan.
Bongo no more........... ;-(
dave_aber
Re: Flashing Dummy Alarm LED.
Post by dave_aber » Wed Nov 25, 2009 10:35 pm
Just spend £50 on an Aldi stereo!
Image...Image
Post by Doone » Wed Nov 25, 2009 10:38 pm
Why? :) Are they the ones where there's a flashing LED when you remove the face plate?
stilldesperate
Post by stilldesperate » Wed Nov 25, 2009 10:40 pm
Places like Maplins do flashing LED's, the old way was that you had to put a resistor in the circuit, to limit the current, but I think they work across 12v ok now.
All you would need is an LED, and the ability to solder a couple of leads onto the legs - they have to be the right way round, they usually have a "flat" moulded into them, this is the negative side.
I'll post a link to some LEDs in a mo
SD
"The older I get, the faster I was"
stilldesperate
Post by stilldesperate » Wed Nov 25, 2009 10:46 pm
Maplins do a "dummy" security LED, click HERE
The current drain is minimal, you could run it for months before your battery drained.
You've a Maplins in S0T, 01782 749947
SD
daveblueozzie
Post by daveblueozzie » Wed Nov 25, 2009 10:46 pm
Lost without my Bongo.
dandemann8
Post by dandemann8 » Wed Nov 25, 2009 10:50 pm
Thanks gents, now just gotta wire the thing in when I get one :lol: :lol: :lol: :lol:
Forgot all about Maplins, that will be my first stop tomorrow.
Thanks again.
kawasaki kid
Post by kawasaki kid » Wed Nov 25, 2009 10:50 pm
All you need is to find a permanent live from under the dash and take the feed for the led from that and put the wire from the other side of the led to earth - simple electrickery me thinks :roll: - an led will draw next to nothing off the battery so you will have no problems thats why they are use in alarms / immobilisers , radios etc as a visual deterent. :)
If I had all the money I ever spent on my Freda ............ I`d spend it on my Freda.
dave_aber
Post by dave_aber » Wed Nov 25, 2009 10:51 pm
Yes. Unless they have locked up, and then the LED doesn't flash until you reset them..... :(
Image...Image
hembramacho
Post by hembramacho » Wed Nov 25, 2009 10:51 pm
Why don't you just fit an alarm/immobiliser. You get a visual deterrant, plus an audible alarm and even if that isn't enough, the immobiliser means it aint going anywhere. :) Plus anyone on this forum now knows that your flashing LED is just a dummy! :shock:
Andrew
dandemann8
Post by dandemann8 » Wed Nov 25, 2009 10:54 pm
kawasaki kid wrote:All you need is to find a permanent live from under the dash and take the feed for the led from that and put the wire from the other side of the led to earth - simple electrickery me thinks :roll: - an led will draw next to nothing off the battery so you will have no problems thats why they are use in alarms / immobilisers , radios etc as a visual deterent. :)
I take it when I find the permanent live and all is wired up right it will only flash when the ignition is off :?:
Me not the best electrician :lol: :lol: :lol: :lol:, but I think I can manage this :!: :!:
Cheers chaps.
dandemann8
Post by dandemann8 » Wed Nov 25, 2009 10:57 pm
hembramacho wrote:Why don't you just fit an alarm/immobiliser. You get a visual deterrant, plus an audible alarm and even if that isn't enough, the immobiliser means it aint going anywhere. :) Plus anyone on this forum now knows that your flashing LED is just a dummy! :shock:
Andrew
Yes this is just a temp measure untill I can get my alarm/immobilisor fitted.
Tony C
Post by Tony C » Wed Nov 25, 2009 11:00 pm
I intend to live forever - so far, so good!
stilldesperate
Post by stilldesperate » Wed Nov 25, 2009 11:02 pm
Good point, dandeman. A permanent live will flash all the time, which is distracting at night if it's in your line-of-sight.
Easiest is to place the LED where you can't see it, but I'm liking the Aldi (?) cheap radio idea!
SD
Post by g8dhe » Wed Nov 25, 2009 11:02 pm
dandemann8 wrote:I take it when I find the permanent live and all is wired up right it will only flash when the ignition is off :?:
Nope a permanent live will mean it will flash all the time! I don't think that there is a line available that only goes to 12 volts when the ignition is off either. You might be better wiring the Flashing LED across the actual Ignition switch, the few milliamps it draws is unlikely to affect anything else. Which vehicle and year do you have, I'll check the diagrams ?
