rev counter and hold light
tuftyfreer
Post by tuftyfreer » Mon Nov 23, 2009 10:14 pm
hello new to this site, just bought a bongo all black very happy but have a problem in the morning on first start up rev counter does not work and hold light flashes slowly. everything is fine after about 20 minutes counter jumps into life and hold light goes out.also fuel gauge only shows half full any help would be very much appreciated because i would like to have a go at fixing it myself as the garage i bought it from is in a land far far away.
cheers
the janner vanner
Re: rev counter and hold light
Post by the janner vanner » Mon Nov 23, 2009 10:26 pm
Hi tuftyfreer, welcome to the mad mad world of the Bongo. Firstly could you put your location on your avatar, it will help you if we know which part of the country you are in. You don't have to give us your address but a city or county would help. To do this go to the top right of the form and click on user control panel then click profile, scroll down and enter your location. Cheers
The Janner Vanner
mister munkey
Post by mister munkey » Mon Nov 23, 2009 10:35 pm
It could be two seperate issues but the tacho reads from the gearbox.
If the Hold light is flashing in a particular sequence, chances are its advising of a gearbox problem.
Theres a factsheet in the Members area that lists what means what . . . .
8)
Last edited by mister munkey on Mon Nov 23, 2009 10:52 pm, edited 1 time in total.
maxheadroom
Post by maxheadroom » Mon Nov 23, 2009 10:51 pm
Hi and welcome :D
Take a look at this link it may help....
http://www.igmaynard.co.uk/bongo/forum/ ... ht#p219269
Keep the Faith
Pablobongo
Post by Pablobongo » Tue Nov 24, 2009 8:52 am
Fuel gauge issue is probably a bad earth, not a major DIY fix....try this link
http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=33920 :D
Paul 2002 V6Image
tuftyfreer
Post by tuftyfreer » Wed Jan 20, 2010 11:45 pm
thanks for all the help sorted fuel gauge need to source a speed sensor for gearbox can anyone let me know where to get one
thanks again
westonwarrior
Post by westonwarrior » Thu Jan 21, 2010 8:57 am
is your speedo chipped?
or could be a loose connection at the rear of the cluster
Post by Doone » Thu Jan 21, 2010 2:22 pm
Good advice from Rob. Unless it's been diagnosed as a speed sensor problem, it's wise to check the basics first. :)
Post by missfixit70 » Thu Jan 21, 2010 2:43 pm
Is it regularly about 20 minutes before the fault clears? Is it a bit reluctant to start or does it turn over nice & quick & catch instantly? Check your battery voltage before you start & then check your alternator is chucking voltage in ok at somewhere between 13.8v & 14.5v, sounds to me like the battery is a bit low on start up then after 20 minutes it's charged up enough. If so, this would suggest an iffy battery or a drain when it's parked up. Might be completely off the mark, but worth checking?
