central locking not working
Kazanne
Post by Kazanne » Mon Nov 09, 2009 2:04 pm
Hi Guys and Girls, My central locking has stopped working is it likely to be the fuse or something more serious. Thanks Kazanne :roll:
jaylee
Re: central locking not working
Post by jaylee » Mon Nov 09, 2009 2:36 pm
Is this the manual locking to all doors that works from the drivers door only, then?
Try checking yer 30A fuse in the cab first.. (top row green one 4th from the left)
Then try the drivers door loom..? With the door open lock & unlock the door from the inside & juggle the loom or strip the loom casing off & check the bundle for chaffing or breakage..
You could take the door card off first & see if the connection block to the CL has come adrift?? ( Its in the centre of the door. If i remember?)
If all is OK the CL relay could be down..?
Post by Bob » Mon Nov 09, 2009 2:46 pm
Very common for the loom to fail where it passes between the A pillar and the door.
Simlpe enough to solder back up.
Kazanne
Post by Kazanne » Mon Nov 09, 2009 5:57 pm
Yes when I lock or unlock drivers door thats the only one that works. Will look at fuses tomorrow in the daylight and try that first. Many thanks. :roll:
Post by missfixit70 » Mon Nov 09, 2009 7:08 pm
Could just be low battery? mine played up when my LB was dying last year.
