				Oil filters
				Posted: Fri Nov 06, 2009 3:14 pm
				by alexknill
				Does anyone know if Halfords do an oil filter to fit 2.5td?
Also, I've read the document about oils - which is the best to use?
I've just looked and realised that the Bongo needs an oil change (done just over 5000km) - I have a chance to do it this weekend and can't use Bongo Fury shop until 16th!
				Re: Oil filters
				Posted: Fri Nov 06, 2009 3:36 pm
				by Muzorewa
				Sounds like me & thee are the only people who change our oil at 5,000km intervals, which for me means every 4 or 5 weeks
				Re: Oil filters
				Posted: Fri Nov 06, 2009 3:44 pm
				by francophile1947
				They won't list a filter but, if you look at the Compatible Parts database in the Member's Area, they should be able to look it up by comparing other makes part numbers - usually cheaper from other motor accessory shops though
				Re: Oil filters
				Posted: Fri Nov 06, 2009 4:27 pm
				by mikexgough
				or even local Motor factors........   any of these will do - as they are the same filter.....different maker...........
AC	X572
ADL	ADC42104
ADL	ADC42105
ALCO	SP997
AMC	M0400
AMC	M0400K
AMC	MO400
BOSCH	0986452042
BOSCH	P2042
CHAMPION	K270
CLEAN	DO827
COOPERS	Z1041
CROSLAND	2087
DELPHI	FX0152
FIAAM	FT5151
FILTRON	OP587
FRAM	PH6355
HYUNDAI	2630042000
JAPANPARTS	JFO505
JAPANPARTS	JFO505P
KIA	OK55212603A
KNECHT-MAHLE	OC274
MANN & HUMMEL	WP928/81
MANN & HUMMEL	WP928/83
MAZDA	VSY114302
MICRO	T7317
MITSUBISHI	MD069782
MITSUBISHI	MD069785
MITSUBISHI	MD184086
MOTAQUIP	VFL304
NIPPARTS	J1315005
PBR	BC1211
POWERTRAIN	PMFL145
PURFLUX	LS740A
PUROLATOR	L27998
PUROLATOR	L37733
QH	QOF5508
RYKO	Z313
SOLID AUTOS	M302004
TECNOCAR	R1302
TECNOCAR	RD1001
TEHO	OK161
TJ	FB5508
UFI	23.237.00
UNION	C321
UNIPART	GFE329
VIC	C306
				Re: Oil filters
				Posted: Sun Nov 08, 2009 8:40 pm
				by alexknill
				Thanks for the advice
SAS in Harrogate were brilliant!
				Re: Oil filters
				Posted: Mon Nov 09, 2009 10:52 am
				by chiefster1976
				You have RYCO /RYCKO Z313. is this a correct oil filter for 2.5TD?  I have seen ryco Z9 in my local motor factor in Australia, same filter that fits my 2.5TD Mazda B2500 UTE...  Not sure if it will fit ??
mikexgough wrote:or even local Motor factors........   any of these will do - as they are the same filter.....different maker...........
AC	X572
ADL	ADC42104
ADL	ADC42105
ALCO	SP997
AMC	M0400
AMC	M0400K
AMC	MO400
BOSCH	0986452042
BOSCH	P2042
CHAMPION	K270
CLEAN	DO827
COOPERS	Z1041
CROSLAND	2087
DELPHI	FX0152
FIAAM	FT5151
FILTRON	OP587
FRAM	PH6355
HYUNDAI	2630042000
JAPANPARTS	JFO505
JAPANPARTS	JFO505P
KIA	OK55212603A
KNECHT-MAHLE	OC274
MAZDA	VSY114302
MICRO	T7317
MITSUBISHI	MD069782
MITSUBISHI	MD069785
MITSUBISHI	MD184086
MOTAQUIP	VFL304
NIPPARTS	J1315005
PBR	BC1211
POWERTRAIN	PMFL145
PURFLUX	LS740A
PUROLATOR	L27998
PUROLATOR	L37733
QH	QOF5508
RYKO	Z313
SOLID AUTOS	M302004
TECNOCAR	R1302
TECNOCAR	RD1001
TEHO	OK161
TJ	FB5508
UFI	23.237.00
UNION	C321
UNIPART	GFE329
VIC	C306
