Rear FOGS
chiefster1976
Rear FOGS
Post by chiefster1976 » Thu Nov 05, 2009 12:36 pm
1. DO Bongos generally come with rear fog lights?? i have a 1995 4WD auto free top Diesel.WLT...
I am in Oz.. there IS a fog switch on the right of the steering wheel and lights up but no fog lights at the rear showing... There are bulbs present in the lights clusters and wiring loom connected to the switch...
2. TO the right of the fog switch there is a coin slot then next to that is a blank off switch cover, BUT behind the blank is a wiring loom and plug!! :shock:
What is this spare loom for???? Im thinking that it MAY BE for a PRE heat switch?? My last bongo had one but this one has not.
Racing green with extras!!Self build full side conversion which rocks!!!
Re: Rear FOGS
Post by francophile1947 » Thu Nov 05, 2009 12:39 pm
Answer to question 1 is no - they are an aftermarket fit in the UK, to make it legal for road use.
No idea about the other switch :?
321Away
Re: Rear FOGS
Post by 321Away » Thu Nov 05, 2009 2:12 pm
The fog light is fitted for the mot as its a UK requirement.
The wiring loom behind the blank is if you have low level 'boy racer' front fog lights fitted.
Julian
Re: Rear FOGS
Post by missfixit70 » Thu Nov 05, 2009 3:50 pm
chiefster1976 wrote:There are bulbs present in the lights clusters and wiring loom connected to the switch...
Bulbs where in the light cluster? as standard there should only be tail/stop light, reverse light & indicator, unless someone has already fitted an extra set of fogs in the spare space behind the "spare" reflector panel as per - http://www.igmaynard.co.uk/bongo/forum/ ... +fog+light
