Diesel - Won't rev passed 2200rpm
1998 bongo diesel when trottle is pressed to floor it wont go past 2200 rpm and i s the same when driving. has anyone go any suggestions as to what might be the problem. thanks in advance pee a dee.
Re: technical
Needs a new fuel filter or the banjo filter is blocked.
Re: technical
Also check the little pipe hasn't come off its connection to the turbocharger
Re: technical
Welcome to the forum
, may be worth your while reading this - http://www.igmaynard.co.uk/bongo/forum/ ... =4&t=35550 .
Be worth checking the air filter too, but I suspect Franco or Mike's suggestions may be what you need.
- dandywarhol
Re: technical
I'l go for the zorst flap - anybody want to start a wager
Re: technical
Good thought. We're overdue for one of those casesdandywarhol wrote:I'l go for the zorst flap - anybody want to start a wager
Re: technical
My Bongo used to be quite sluggish, especially on hills on motorways. Eventually the auto box would change down a couple of gears and I'd sit there going just as slowly as before, but making a lot more noise
As posted elsewhere (http://www.igmaynard.co.uk/bongo/forum/ ... 0&start=15), I found two sheared exhaust studs and evidence of leaks in the EGR system.
Might be worth checking?
Re: technical
Any chance someone could change the title to something applicable to the query?
Re: technical
Donemissfixit70 wrote:Any chance someone could change the title to something applicable to the query?
Re: Diesel - Won't rev passed 2200rpm
Nope
Whatmissfixit70 wrote:Nope
Don't want to be too obvious, but have you checked the throttle cable? It connects to the engine under the drivers side seat. It may have gone slack or is damaged.
PS, my throttle has about an inch of movement before it takes up the slack in the cable. Is it possible to tighen the cable?
many ta,s for suggestions on wont rev passed 2200 rpm will try some of them and report back cheers from pee a dee
Can you not adjust the outer clamp position next to where the cable meets the fuel pump?Is it possible to tighen the cable?
Back off the nuts, and extend the effective outer by moving the cable outer end rearwards...
- dreamwarrioruk
just a random one but this happened to us. i found it to be a bottle that had got sucked onto the air inlet.
mike, jo and emma
