argh!!! coolant leak
alectroll
Post by alectroll » Mon Oct 26, 2009 6:13 pm
Hello again all. got a leak, not me personally but my van! metal pipe running under the drivers side door, leaking from where the pipe is welded to the bracket. noticed it last week as a bit of a seep but now its dripping merrily onto my driveway, had a look on the schematics but cant seem to find the correct diagram. any help appreciated.
thanks in advance.
Re: argh!!! coolant leak
Post by haydn callow » Mon Oct 26, 2009 6:35 pm
Post by missfixit70 » Mon Oct 26, 2009 6:50 pm
If it's the smaller pipe you'll need the rear heater schematics - http://www.lushprojects.com/bongopartsm ... mgno=.html
Post by missfixit70 » Mon Oct 26, 2009 6:52 pm
Bongobits should be able to supply what you need - http://www.bongobits.com/Main.asp?PageN ... Query=pipe
alectroll
Post by alectroll » Mon Oct 26, 2009 7:42 pm
you guys are GOOD!!!! many many thanks for the info!
just checked the coolant level and its not gone down by much so i've got it booked it into the garage for them to have a look etc tomorrow evening, fingers crossed it wont go pop on the way there.
Post by haydn callow » Mon Oct 26, 2009 8:21 pm
SERIOUS WARNING.....unless your garage work on bongos every day...DO NOT let them touch the cooling system..
dave_aber
Post by dave_aber » Mon Oct 26, 2009 8:31 pm
You're going to end up with a new bongo at this rate Alec. Trigger's broom springs to mind. 17 new heads and 13 new handles.
Image...Image
Post by Doone » Mon Oct 26, 2009 10:03 pm
But it was still the same broom. :wink:
Rhod
Post by Rhod » Mon Oct 26, 2009 10:07 pm
missfixit70 wrote:Bongobits should be able to supply what you need - http://www.bongobits.com/Main.asp?PageN ... Query=pipe
Yes, Bongobits can supply - just received both left & right-hand pipes from them today!
alectroll
Post by alectroll » Mon Oct 26, 2009 10:17 pm
LOL, you're not wrong!!! and i've got a set of shocks, for some lucky person to fit, sat on my passenger seat!!! and the guy who does the majority of the work on my van is fully conversant with the coolant system, he's already replaced 1 of the pipes for me and bled the system with no ill effects at all.
dave_aber
Post by dave_aber » Mon Oct 26, 2009 10:30 pm
I'm back a week tomorrow if you don't get the shocks done before. Can't get the pit for 2 more weeks after that though - would need a set of ramps.
Image...Image
