gearbox oil
alectroll
gearbox oil
Post by alectroll » Fri Oct 23, 2009 4:08 pm
Hi all again, just checked my gearbox oil and found it to be a little low, how do i replen it? and which oil is the correct one?
Thanks, Alec.
Re: gearbox oil
Post by francophile1947 » Fri Oct 23, 2009 5:31 pm
Manual or automatic?
alectroll
Re: gearbox oil
Post by alectroll » Fri Oct 23, 2009 6:30 pm
auto box, 2.5td
Re: gearbox oil
Post by missfixit70 » Fri Oct 23, 2009 6:32 pm
Down the dipstick tube with DIII.
I'm also assuming you've checked the level with engine/'box warmed up to normal, leave it running, both brakes on, chocked, range slowly through the gears then leave it in D to dip it. Good opportunity to do a change - http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=30096
