Tempermental AFT
greenbean
Tempermental AFT
Post by greenbean » Mon Oct 19, 2009 1:46 pm
Hello All
My Auto Free Top is a bit tempermental especially when closing. I press the cancel button in the roof space, the warning sounds, I then press the close button but nothing happens. I have to repeat this process numerous times, then when it feels like it, it decides to kick into life and close. The same happens on raising the roof as well but not quite as often.
Any advice would be greatly received
Re: Tempermental AFT
Post by g8dhe » Mon Oct 19, 2009 1:58 pm
The usual problem is the handbrake safety lock switch, but I haven't actually noticed if its possible to release the Cancel AFT and start the beeping when the handbrake isn't on to start with. I'll check myself later, unless someone can confirm the situation. If it is the handbrake switch then a jiggle and clean of the contacts is al that's normally necessary.
Post by missfixit70 » Mon Oct 19, 2009 3:44 pm
If not the handbrake switch, it may be worth checking the connector blocks at the back of the AFT visible from out side on the drivers side, exposed to the elements, make sure they are all making contact ok, sometimes disconnecting & reconnecting a few times cleans up the contact faces/points.
greenbean
Post by greenbean » Tue Oct 20, 2009 3:03 pm
Thanks for the advice. I'll give your suggestions a go
