Well at last the TM2 and LCA are on and please no horse and stable door cracks. It was a bit fiddly but not too difficult for a numpty like me. I don't know how you all get the sensor wire through to the cab but where the shifter cable goes through the bulk head there is a lovely big rubber grommit there to drill a hole in..
Found myself having to slpice both the TM2 and LCA lives into the back of the ciggy lighter.
Is there any where else or is it possible to run a cable from somewhere with a load of switched lives?
Tony
Just fitted my TM2 and LCA
- Tribal Elder
Re: Just fitted my TM2 and LCA
Two big rubber grommets in the bulkhead.. One behind the header tank, & one the other side where the main loom goes through..
Yep, anywhere live when the ignition on.. Fair play!!
