Wobbly freetop
Gripped
Wobbly freetop
Post by Gripped » Mon Oct 12, 2009 9:57 pm
When I lower the freetop, about half way down it shakes from side to side. Is this common?
Any ideas on a fix?
Re: Wobbly freetop
Post by missfixit70 » Mon Oct 12, 2009 10:03 pm
I bet it creaks & groans too? Common issue, lubrication is the key, I use a bit of silicon spray on the rams & moving bits.
Gripped
Re: Wobbly freetop
Post by Gripped » Mon Oct 12, 2009 10:07 pm
Thanks for the quick reply. I also had my first failed full freetop elevation (I'll try and avoid the obvious term :oops: ) yesterday, so maybe that'll be helped by lube. It does seem that the motor is a bit underpowered though - seems to struggle a bit.
daveblueozzie
Re: Wobbly freetop
Post by daveblueozzie » Mon Oct 12, 2009 10:08 pm
Gripped wrote:Thanks for the quick reply. I also had my first failed full freetop elevation (I'll try and avoid the obvious term :oops: ) yesterday, so maybe that'll be helped by lube. It does seem that the motor is a bit underpowered though - seems to struggle a bit.
do you have the engine on when raising/ lowering the roof ? this helps to power the motors.
Lost without my Bongo.
Re: Wobbly freetop
Post by missfixit70 » Mon Oct 12, 2009 10:11 pm
Sometimes it needs to be lowered a bit & raised again to reach lock out succesfully, or maybe even a bit of a helping hand as it's raising, especially if it's a bit sticky & maybe hasn't been used for a while & as DBO says, engine running is a must.
kawasaki kid
Re: Wobbly freetop
Post by kawasaki kid » Mon Oct 12, 2009 10:14 pm
When raising the roof you need to have the engine running as you will soon drain the battery also if the roof hasn`t been raised for a while you may have to give the roof a little help for the last few millimetres as the canvas may be a little bit stiff. Hope this helps. :)
If I had all the money I ever spent on my Freda ............ I`d spend it on my Freda.
westonwarrior
Re: Wobbly freetop
Post by westonwarrior » Mon Oct 12, 2009 10:17 pm
Also leave the top vent unzipped to let air in / out, eases the pressure a bit
Re: Wobbly freetop
Post by Bob » Mon Oct 12, 2009 10:38 pm
As well as keeping the battery charged running the engine means you can't hear it creaking and groaning, much better for peace of mind.
dreamwarrioruk
Re: Wobbly freetop
Post by dreamwarrioruk » Mon Oct 12, 2009 10:51 pm
missfixit70 wrote:I bet it creaks & groans too? Common issue, lubrication is the key, I use a bit of silicon spray on the rams & moving bits.
i have this problem sometimes but the bongo roof is fine :oops: :oops: :-&
mike, jo and emma
Re: Wobbly freetop
Post by bigdaddycain » Tue Oct 13, 2009 11:51 am
My freetop roof is exactly the same... I find that spray on lithium white grease seems to cure the wobble/creaks... But it does only last maybe 10 or 12 roof up/downs procedures. :? Then the wobble and creaks surely return... #-o
munroman
Re: Wobbly freetop
Post by munroman » Tue Oct 13, 2009 12:22 pm
I find it helps if the sliding door is open to allow air in/out, as the roof acts as a giant bellows.
MountainGoat
Re: Wobbly freetop
Post by MountainGoat » Tue Oct 13, 2009 2:53 pm
Many of us have removed the trap door by drilling out the pins. This has three advantages. Avoids the bellows effect and make closing the roof easier, circulates the air a little better thereore helping to dry out roof tent a bit quicker and allows the inner roor to be pushed up more easily especially if you are using a thick (3" ) mattress in the aft. The trap door is stored in the roof tent to be replaced to form a bed when required.
Tony
