Aerials
tim & angie
Aerials
Post by tim & angie » Wed Sep 23, 2009 1:00 am
Weve just fitted a new cd/fm radio (Halfords) to our newly purchaced Bongo but still cant get a decent radio reception. Weve got what appears to be a standard factory fit extending arial mounted in the door/windsceen pillar. Do all you other Bongonoughts get good radio reception with the standard arial? in which case I will get another Mazda one from the club shop, or is it worth replacing it with a new pillar mount arial from my local motor spares shop which may or may not fit the existing hole? Any feed-back would be much appreciated.
Tim
Triple/R
Re: Arials
Post by Triple/R » Wed Sep 23, 2009 7:54 am
tim & angie wrote:Hi
Tim
Hi Tim & welcome---i also bought mine from Halfords--reception is spot on but my aeriel is positioned probably half way down the Bongo just underneath the guttering & i reckon mine is a standard factory fit!---what years your Bongo???
Regards Ray & Christine
jaylee
Re: Arials
Post by jaylee » Wed Sep 23, 2009 9:47 am
Hi Tim, Your description of the arial fitting, suggests you have a tintop. With the Honda owned era Rover style one piece arial that retracts down the side of the windscreen?
Different to the Freetop arial.
My tintop arial reception is as good as any other car arial.. I could be wrong but there could be a second connection to the arial coaxial somewhere on the drivers side or widow pillar..? Check to see this has not disconnected from an extension that leads to the radio...?
You don't have a European expander fitted from the possible previous Japanese radio..?
Hope this can help! :D
bongoben
Re: Arials
Post by bongoben » Wed Sep 23, 2009 9:58 am
jaylee wrote:Hi Tim, Your description of the arial fitting, suggests you have a tintop. With the Honda owned era Rover style one piece arial that retracts down the side of the windscreen?
Same as jaylee, my tintop aerial works perfectly and is easily reached
from the drivers seat when you need to retract it quickly.
stringman
Re: Aerials
Post by stringman » Wed Sep 23, 2009 7:19 pm
I live in Aylesbury and used to run a car radio shop.
Want me to have a look??
Tin top Bongo camper, Peugeot Partner Combi, Kawasaki ZRX1100, Yamaha SR250SE
tim & angie
Re: Arials
Post by tim & angie » Wed Sep 23, 2009 8:23 pm
Thanks for that Jaylee, ours is a tintop so I will have a look at the weekend for another connection from the arial. I still have the old japanese cassette/radio, what does a European expander look like????
Tim
tim & angie
Re: Aerials
Post by tim & angie » Wed Sep 23, 2009 8:31 pm
Thanks stringman. I will have a fiddle with it at the weekend but if still have no joy might take you up on your offer
Tim
stringman wrote:I live in Aylesbury and used to run a car radio shop.
jaylee
Re: Aerials
Post by jaylee » Wed Sep 23, 2009 9:46 pm
tim & angie wrote:Thanks for that Jaylee, ours is a tintop so I will have a look at the weekend for another connection from the arial. I still have the old japanese cassette/radio, what does a European expander look like????
Tim
It should look something like this.. http://cgi.ebay.co.uk/Japanese-Car-Radi ... 5002r16901
not so old
Re: Aerials
Post by not so old » Wed Sep 23, 2009 9:56 pm
Hi Tim and Angie, We had a wave expander put on our original radio, but the stations were few, so we had a new radio fitted and it is fine. I don't know if the expander was taken out when the new radio was fitted though. We had one of Ian's aerials fitted too. I'm not much help really, but I'm sure stringman would know. :D I hope you are still enjoying your lovely Bongo
Cheers Anna
Re: Aerials
Post by bigdaddycain » Thu Sep 24, 2009 1:30 am
Re-check the coax connection into the back of your head unit...if the cables were a bit tangled it could have tugged the plug from the rear of the unit a little as you pushed the stereo back into the radio aperture. :wink:
tim & angie
Re: Aerials
Post by tim & angie » Mon Sep 28, 2009 10:59 pm
Thanks for all the replies re the arial. I had a fiddle under the dash and the co-ax plug into the socket at the base of the window pillar was loose, all working well now.
jaylee
Re: Aerials
Post by jaylee » Tue Sep 29, 2009 2:11 am
tim & angie wrote:Thanks for all the replies re the arial. I had a fiddle under the dash and the co-ax plug into the socket at the base of the window pillar was loose, all working well now.
You made my day T&A..!! :D I don't normally get nothing right.... :oops: :oops: :lol: :lol: :P
Glad you got it sorted! :D
tim & angie
Re: Aerials
Post by tim & angie » Tue Sep 29, 2009 11:53 pm
You were spot on Jaylee with the second co-ax connection so thanks again. By the way I had a look at the the old jap radio and it isnt fitted with European expander so cant help you there.
Tim
