is there an easy way to bleed the fuel system on a diesel
draper3000
Post by draper3000 » Sat Sep 12, 2009 8:02 pm
Is there an easy way to bleed the fuel system on a diesel Bongo 2.5.
Does anyone know of any way to do it, or what fact sheet to read from members area..
I have searched forum but can find a how to...
Jon
Re: is there an easy way to bleed the fuel system on a diesel
Post by missfixit70 » Sat Sep 12, 2009 8:05 pm
The factsheets are in the members area, I think 3 different methods are described.
draper3000
Post by draper3000 » Sat Sep 12, 2009 8:14 pm
yeah sorry did'nt make myself very clear...
I am a member and can access the factsheets....do you know which one refers to bleeding fuel?
Post by missfixit70 » Sat Sep 12, 2009 8:32 pm
#-o sorry, not with it, I was referring to coolant, fuel should be self priming. I've just replaced a fuel filter, filled the new one with injector cleaner, carefully screwed it back on, started first turn.
I'd check you've got no leaks & the pick up in the tank isn't blocked as well as the fuel strainer & filter.
Post by missfixit70 » Sat Sep 12, 2009 8:39 pm
This is runnig in parallel with a very similar thread form the same poster so I'll lock this one to prevent confusion & any further comments should go here - http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=34780
