power steering fluid (where)
This is prob a very daft question but where do i check this?? may be me but cant find info anywhere!
cheers guys
cheers guys
Re: power steering fluid (where)
Small plastic bottle under driver's seat
Woo Hoo - I beat Kirsty
under the drivers seat, it's marked power steering fluid
Damn too slow again
Damn too slow again
- Tribal Elder
Under drivers seat. Remove centre console (2x plastic nuts) lift carpet on the front of seat and unclip 2 black clips there and one under where the console was. White plastic reservoir marked power steering.
My excuse is I am in the pub.
cheers for the quick responses guys. can any 1 tell me what the dipstick is to the left and rear of the ps tank is for???
Also can I get a new oil dipstick from any where as mine broke yest when i was pushing it back in
- mikexgough
other dipstick is Auto transmission level............
New engine oil dipstick.......http://www.bongobits.com/Main.asp?PageN ... roduct=230
ATF level should be checked with the engine running and properly warmed up, ie after at least a 20 min drive. I check mine with hand & footbrake on (ideally chocks as well - elf & safety
), range slowly through all the gears & then let it settle in D for a minute then check the level.
I've just found (new bongo owner!) the power steering tank, and the level is low (good 1 to 2 inches below minimum, and the steering is whiny.
I have purchased some fluid to top it up (dexron 11) , but there is a gungy dirty yellow plug at the bottom of the neck, and I am thinking just tipping new fluid in while that is there might not be a great plan?
Advice needed!
Can I just pour in new fluid?
Do I need to remove the gunge first?
If so, how do i do this? It is at the bottom of a narrow 3 inch neck....
I'm stuck!!
Also, I went in looking for the transmission fluid tank / dipstick, but couldn't see it. Before "going in" again, where do I find this?
I feel so bongo innocent!!!!!
Advice needed!
I'm stuck!!
The gungy yellow plug (if I remember correctly) is a gauze filter - pull it out and clean it. The grade of ATF for the gearbox and power steering is Dexron 3 - I don't know what the difference is or whether or not they should be mixed
Gearbox dipstick is under the driver's seat at the back of the engine. make sure you read the instructions on how to check the level (as posted by Kirsty further up this thread)
When I say gungy yellow plug, i suppose i meant plug of gunge, not a plug. Not sure it looked like there was gauze down there, but there might have been (i failed to find the gearbox dipstick after all!!!).
Just don't know how to fish something out from such a long narrow neck - kinda looks like it should be scooped out...
I think you'll find the whole yellow thing lifts out, but it's been a while since I did it
The filter bit just lifts out of the PS bottle, then you can flush it clean.
- Alacrity
- Tribal Elder
Dexron 2 & 3 will mix OK.
Hi Sharon, Pity you did not make the meet at Chatelherault Country Park in Hamilton yesterday. Steviebongo could have explained to you what to do, he is a Ford Mechanic.
Tony
Tony
There's a filter in there?missfixit70 wrote:The filter bit just lifts out of the PS bottle, then you can flush it clean.
