Car Alarm Questions
apole
Car Alarm Questions
Post by apole » Fri Aug 21, 2009 9:14 am
Seen this the other night and was wondering about getting one for the bongo.
http://www.maplin.co.uk/Module.aspx?ModuleNo=219353
Does anyone know if it's easy to wire it into the central locking so that you can use the remote for the alarm to lock and unlock the doors (my remote key is getting old and tired)?
Many thanks.
Andy
Ron Miel
Re: Car Alarm Questions
Post by Ron Miel » Fri Aug 21, 2009 9:44 am
Don't know the answer to that one Andy. However, I would spend a bit more, and get a system which also controls the engine immobiliser (e.g. http://www.dynamicsounds.co.uk/hornet-m ... -9688.html), as that will not only improve convenience but also security and to a much greater degree. The Bongo central locking as such is no security, as anybody with a wire coat hanger can defeat it. Cheers, David
stevedon
Post by stevedon » Fri Aug 21, 2009 9:18 pm
it will work however you may need to fit an additional actuator in the drivers door, i did but i didnt have an blipper to start with.
cheffy34
Post by cheffy34 » Fri Aug 21, 2009 11:42 pm
Apole took me a few days to wire my cat one in but i soldered it all in and double checked everything 3 times :? , i bought from hawk, had it in 18 month now really good :!: im chuffed with it, i took advice from a couple of very helpfull peeps knowledge on here :wink: I reckon there is a way to wire into the orig mazda door fob electricery thing think it is behind the glove box i think, but it is easier to put an actuator in direct from the alarm to the driver door pin :wink:
Dar
stringman
Post by stringman » Sat Aug 22, 2009 9:16 am
If you have the factory remote central locking you will already have an actuator in the door so it is fairly easy to wire the alarm up to the wiring for this. In my P reg old shape the whole radio control for the central locking was in the drivers door so I removed this and simply ran two wires from the alarm to the two wires that went to the original actuator. I used a Meta M99 T2 alarm (we fitted hundreds of these when we had the contract for alarms down at Trades Sales in Slough) and two years on it still works as well as the day I fitted it.
Tin top Bongo camper, Peugeot Partner Combi, Kawasaki ZRX1100, Yamaha SR250SE
apole
Post by apole » Mon Aug 24, 2009 8:33 am
Thanks for the info.
Main reason I'm looking to get one of these alarms is to replace the key remote controled locking, the key is starting to get tired.
I'll check this other alarm out, thanks again.
Andy
