Coolant alarm gone off on one?
chipvan
Post by chipvan » Thu Aug 20, 2009 6:43 pm
Our haydon is now Reading 001 and no temp,on manual it says short out or wrong polarity.had a look at sensor wire and all looks good,has anyone got any pointers can't seem to crack it!
Jez
Re: Coolant alarm gone off on one?
Post by missfixit70 » Thu Aug 20, 2009 8:27 pm
Phone Haydn? I take it you mean the TM2?
Post by haydn callow » Thu Aug 20, 2009 9:25 pm
I have sent you a PM.
Post by haydn callow » Thu Aug 20, 2009 9:56 pm
Assuming it has been working o.k. since you fitted it...It sounds as though the sensor cable has been damaged and shorted itself out.....Send it back and I should be able to fix it or fit a new cable.
Failing that I will send a replacement.
Go to the web site below to get my contact details....we will sort it asap.
Post by haydn callow » Fri Aug 21, 2009 9:34 am
Does it (when you switch on) go stright to 001, or, does it read the temp then go to 001 ??
chipvan
Post by chipvan » Fri Aug 21, 2009 11:42 am
Yep it goes to that Reading without anyother readings,all was working a treat,and very happy with it
I am not havin a moan,just like fixing it myself when I can.
Thanks for the help,will send it back and see what you can do
regards jez
