odd one today
peanutcrusher
odd one today
Post by peanutcrusher » Sun Aug 16, 2009 9:38 pm
i parked up today put the roof up this was all fine. came to the end of the when to put the roof as normal but when i started the van no beeping and no roof light showing on the dash :( :?
pressed the close button but nothing happened :?
i went round pressed the roof cancel button up in the roof the beeping then start and i could close the roof, however it did not stop it closed all the way down.
anyone got any ideas?
Bongo now work later !!! :) :)
hembramacho
Re: odd one today
Post by hembramacho » Sun Aug 16, 2009 9:54 pm
Sorry but I'm missing the problem here.
If you pressed the roof cancel button and the roof came down, not sure what the issue is?
It won't come down if the ignition isn't on and the roof cancel button isn't pressed anyway.
Sounds normal to me!!
Andrew
aitch
Location: in a place far, far away, well Somerset for now!!!
Re: odd one today
Post by aitch » Sun Aug 16, 2009 9:55 pm
try it again it might have just been a blip mine did this once and never again = always stops and then starts again when the button is pushed for a second time.
hembramacho
Re: odd one today
Post by hembramacho » Sun Aug 16, 2009 9:57 pm
When bringing the roof down it always stoppes 2/3s of the way down so as to check nothing is caught up, etc. This is perfectly normal.
Andrew
jaylee
Re: odd one today
Post by jaylee » Sun Aug 16, 2009 10:02 pm
The sunroof on the tin top's the same...
Stops about 1/2 to 2,3rds the way shut.. Re press the button, & it carries on till closed!
aitch
Re: odd one today
Post by aitch » Sun Aug 16, 2009 10:24 pm
Are sun roofs in tintops electric then ???? didn't know that!!!!
peanutcrusher
Re: odd one today
Post by peanutcrusher » Sun Aug 16, 2009 11:58 pm
hembramacho wrote:Sorry but I'm missing the problem here.
Andrew
the problem is that the van did not seem to know the roof was up in the first case so i could close it.
Re: odd one today
Post by missfixit70 » Mon Aug 17, 2009 12:07 am
Sounds like one of the microswitches may be starting to play up.
jaylee
Re: odd one today
Post by jaylee » Mon Aug 17, 2009 12:44 pm
aitch wrote:Are sun roofs in tintops electric then ???? didn't know that!!!!
Yep! Same switch... (No beep.) Though the later Tin Top's don't have sunroofs fitted apparently... Certainly the later ones i've seen! http://www.lushprojects.com/bongopartsm ... 1of02.html
scanner
Re: odd one today
Post by scanner » Mon Aug 17, 2009 12:56 pm
Are bears catholic? Does the Pope........errr
Sorry got that the wrong way round.
Something on the Bongo that could be electric, but isn't :shock: - now that would be novel. :lol:
