leisure battery
tay
leisure battery
Post by tay » Mon Aug 10, 2009 5:36 pm
hi guys,not been around for a while busy,busy.if leisure bat is completly flat is a split charge relay set up good enough to charge it back up or does it need a helping hand from the mains via a bat charger cheers tay
i chose not to choose life ....i chose a bongo instead
Re: leisure battery
Post by francophile1947 » Mon Aug 10, 2009 5:39 pm
Ideally a battery charger. A really flat battery often causes problems with overloading split charge relays. Also, a trickle charge is kinder to the battery.
tay
Re: leisure battery
Post by tay » Mon Aug 10, 2009 5:48 pm
thanks for the fast reply.i think i'll have to disconnect and and ask site owner if i can charge it up.forgot to mention im on hols no hook up . You live and learn eh.
