Good morning!
How do i remove the windscreen water jets on the front of my Bongo?
Your thoughts much appreciated.
Windscreen washers
- Tribal Elder
Re: Windscreen washers
not sure on the bongo but normally a slight push away from the securing pin or leg and it should pop oot or u pop it oot from behind,under the bonnet that is.why do u want ure jets oot are they blocked?
cheers stevie
cheers stevie
